Question about Dryers
My dryer goes on forever but does not get hot and the cloths are still a bit damp. what would be an approximate to have it fixed
  • 715 Answers
Approx$ 65.00
Posted on Oct 08, 2009
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
I have a AEG L12719VIT. The dryer cycle seems to be overheating or not draining. The clothes are very hot, but still damp. Even when we reduce the load considerably the same thing happens. It pause's...
heatman101
Jul 20, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
I have jst purchased this washer today, however the dryer takes ages,,,,,,their seems to be water going in when its drying, clothes come out hot, but still as damp as when i put them into dry.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
Hope this helps.
Feb 11, 2011 | Hotpoint Ariston WD440G Front Load...
The dryer is hot but the cloths are damp after 2 hours in the dryer..its hot but the cloths are still damp?
check the air in let and out let pipe are not blocked up with fluff if the dryer cant breath there will be little hot air going through the cloths to dry them out,,,also check the "dust filters"
Aug 12, 2010 | Frigidaire Dryers
GE DWSR463EGWW electric dryer takes forever to dry clothes. Heating element comes on but then goes off. Where do I locate the thermal fuse if that is the problem.
The thermal fuse only shuts off the elements if the proper air flow isn't acheived. If the clothes are hot but still damp after the drying cycle then you have a blockage in the dryer exhaust either at the hose at the back of the machine or in the lint filter area. Check both and clean and your problem should be solved.
Hope this helped you
Dave
Jan 14, 2010 | GE DWSR463EGWW Electric Dryer
The Dryer runs forever and the clothes dont dry
there are two elements on the back wall of the dryer and if one goes it will still get warm but not to dry all the way and will not trigger the heat sensor to finish
Dec 12, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Zanussi T/Dryer - clothes damp
Check and clean filter/s, if it is vented through a hose, make sure it is not blocked or restricted in any way
Please leave feedback.
Thanks.
Nov 13, 2009 | Dryers
Maytag electric dryer model mde308dayw not heeting up
CHECK YOUR WALL VENT AND DRYER VENT AND MAKE SURE THEY ARE CLEAR,ALOT OF THE TIME IF BLOCK THEY HOLD THE DAMP HOT AIR IN THE DRYER AND WILL TAKE FOREVER TO DRY,IF NOT THAT IT CAN ONLY BE YOUR HEATER BOX OR HEATER BOX FUSE,IF YOU HAVE A METER YOU CAN CHECK BOTH,LET ME KNOW-MIKE
Dec 06, 2008 | Dryers
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
