Question about Nintendo Wii Console
Remote won't activate - Nintendo Wii Console
    President:
  • 787 Answers
Make sure the batteries are inserted correctly. Open the front cover on Wii console and push the red button there.Then push the red button on Wii Remote who find next to batteries.
Posted on Oct 08, 2009
Back hatch won~t open with remote or inside door locks will open manually nothing stuck or jammed?
Found this wiring diagram for lift gate, if that is what we're talking about? Not only check the fuses, check fuse circuit for voltage. Use a testlite.
Apr 21, 2016 | 2008 Pontiac Torrent
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have 2002 avalanch that won't start guy told me that it was remote start problems could that keep it from starting with the key?
what does it do? does it turn over will not fire? not turn over or turn over and die right away? need some more info before i can give more detailed advice, the remote start shouldnt hold it up unless its a alarm/starter with the starter disable active.
Sep 06, 2011 | Chevrolet Avalanche Cars & Trucks
2004 Hyundai Elantra won't start, emergency flashers keep blinking, can't shut off, lights dim, can't jump start, clicking from under dash from relays. What could it be?
The 'Keyless Entry & Burglar Alarm System" is activated. You must 'Disarm' the system using the Keyless Entry Remove (Key Fob) to "Reset" the system. The reason the engine won't start is due to the burglar alarm - it has a "Starter Kill" circuit which is activated when the alarm is activated. The alarm must be DEactivated to DEactivate the 'Starter Kill' circuit.
Another way to start the engine is to get in the car, put the key in the ignition and turn it to 'ON" and wait 3 to 5 minutes until the emergency flashers stop/turn off. Afterward, you should be able to start the engine. NOTE: This does NOT reset the burglar alarm. It will go off again when you enter the vehicle without using the remote/key fob.
Sep 06, 2011 | Hyundai Elantra Cars & Trucks
I have a 2005 JGC 5.7 hemi and sometimes remotes wont work only when you want to unlock it.If you use the key to open door alarm sounds. what could be the problem?
Have you tried a new battery in the remote, or do you have a second remote you can test. Either your remote is worn out or the battery is dead.
Once you lock the car with your remote it will active the alarm and if you use your key it won't deactive the alarm only your remote will, on some cars putting the key in the ignition will deactive it.
If you can deactive your alarm with your remote and can just manualy lock and unlock your doors and that should prevent your alarm from going off until you get a new remote or battery.
Aug 05, 2011 | 2005 Jeep Grand Cherokee
Someone sold me a Coby HDTV HDMI without a remote. The channel or the volume button on the side of the tv won't work so I got a universal remote. For some reason the only thing the universal remote...
the code that's entered on the remote is the wrong one for the tv. use the instructions for the remote and get the correct code.. for your model or search ebay for the exact remote. also child lock maybe activated on the tv meaning you cant use the buttons on your tv until you use menu on the remote to take it of.
Jun 08, 2011 | Televison & Video
Nintendo Wii Console Logo
71 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
