Question about Saitek Keyboards & Mice
Saitek gamers keyboard
Hi there,i bought a second hand saitek gaming keyboard model:ku-0418 of ebay and 6 of the keys(xcvbnm) dont work,is there anything i can do to fix them?
  • 196 Answers
SOURCE: i need saitek executive ku-0418
try going to for driver s for ur keyboard and mouse
Posted on Jul 28, 2010
0 characters
1 Points
Where can I find a new Firefly Borealis KU-0533 English-German with USB connection
see if firefly or borealis company is still in business to find ku-0533 usb keyboard to find ku-0533 usb keyboard find borealis ku-0533 usb keyboard
Apr 15, 2015 | FireFly Borealis KU-0533 Keyboard
I need saitek executive ku-0418 driver plz
Jul 28, 2010 | Saitek Keyboards & Mice
Key board not working properly
The keybard probably has defective switches. They may have gotten wet or dirt in them. Not worth trying to fix. Buy new one...
They can be had off eBay for about $20 for brand new ones. Have a shop or competent person familiar with electronics work on it if you don''t feel capable.
The keyboard is USUALLY fairly easy to remove... USUALLY the second item to come off on a laptop when opening it.
Jan 29, 2010 | Sony VAIO VGP-WKB1 Keyboard
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF found your culprit. Replace the keyboard or look for updated drivers if they exist.
Jun 02, 2009 | Saitek Eclipse II
Four keys not working on gaming keyboard
i had this prblem before, bought a new one thinking it was broken. Two days after I got it i found a forum post from someone with this prblem too and a solution they had was this;
to uninstall all the logitech software from the computer and then unplug the keyboard from the USB and then uninstalling the keyboard frm Device Manager. shutdwn, plug the USB back in and then startup again.
I tried it and it worked ! I'd just bought a new one for nothing :s
Mar 10, 2009 | Logitech G15 Keyboard
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
Repeating key - cause unknown
No solution here, but I'd like to second that I have a Saitek 1st gen keyboard. One day it began exhibiting the same problems that you are having. When moved to another computer it seemed to work for a month or so but then started acting up again. For my keyboard, it repeats the letters "a" "s" "m" and others. Not sure what is causing it. No spills on the keyboard and it is fairly clean.
Oct 17, 2007 | Saitek Executive PZ18AU Keyboard
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling. remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there. Now remove the top section of the keyboard (the bit with the keys) Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires. Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws. Now at boot up the keyboard will by default be red.
Sep 15, 2007 | Saitek Eclipse II
Keyboards & Mice Logo
128 people viewed this question
Top Saitek Keyboards & Mice Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Saitek Keyboard and Mice Expert? Answer questions, earn points and help others
