Question about Kenmore Dishwashers
I have a delay button on my dishwasher that has 2, 4 and 8hr delays. I pretty much only use the 2hr setting, but the last time I set it for 2hrs it went to 4 by itself and now it won't go to anything but 4hr. Is there a reset button or something I can do? Thanks, Linda Heydt
Krazytech
  • 725 Answers
SOURCE: Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
Posted on Aug 23, 2007
SOURCE: Problem with Admiral DWD1500AWB
Thanks for the solution, I'll look into that.
=aw
Posted on Jan 02, 2008
SOURCE: My SHU53 only starts on 2Hr Delay and water is not getting hot
Hello- Same problem I had- It turns out that my control board (fixed once already- the solder trace on one of the three relays burned open) was junk again, but the solder trace which was fixed before was still ok, so I replaced all three relays on the board (relays are available from Digi-Key) and that fixed it!! The relays cost all of $11.00 INCLUDING SHIPPING - So if you're on a tight budget, this may work for you. Bill
Posted on May 06, 2009
jan mczeal
  • 632 Answers
SOURCE: electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Posted on Aug 31, 2009
SOURCE: whirlpool dishwasher adp 5966 6th sense delay start problem
you hold in the start button untill it goes off
Posted on Sep 05, 2009
My Westinghouse dishwasher is displaying HO2 what does it mean.?
H01-H24 Delay has been selected.so H02 means you have selected two hours delay.
Cancel delay setting if you don't need it.
Time Indicator and delay display:
The time indicator displays the program time and time
remaining for the program
In addition, you can delay the start of the program by
pressing the "+" and "-" buttons before the program is
commenced The delay function is indicated by the letter
"H" followed by the number of hours selected
If you want to change the delay time, you can reset it by
pressing START/PAUSE and then using the "+" and "-"
buttons to select the new delay time, then press START/
PAUSE to activate
Westinghouse WSF6606 User Manual Failure Codes And What To Do In Case Of...
Oct 25, 2017 | Westinghouse Dishwashers
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
The dishwasher is displaying 5H in the time panel is there any way that could happen by pushing the wrong button and is there any way to make it go away
It would help to know the model number to determine the features of your dishwasher. The only guess I can make is that someone pushed the "delay" button and you are now set for a 5 hour delay for starting the dishwasher. Pressing the Delay button a few more times should bring it back to Zero delay.
Feb 28, 2015 | GE Dishwashers
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
Sep 08, 2014 | Belling XOU592 / XOU593 Electric Double...
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
Dishwasher has set to 13 hours delay. How do you cancel this delay?
Did you try unplugging it ?......some will reset if you do ....if that doesnt work try pressing the set button and unplug at the same time.
Feb 25, 2011 | Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Dec 27, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool dishwasher adp 5966 6th sense delay start problem
Mar 12, 2008 | Dishwashers
Aug 23, 2007 | Kenmore 24 in. 16462 / 16464 / 16469...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
