Question about Mossberg Optics
Need to find out how much a 185 KA mossberg bolt action 3 shot 20 gauge is worth
  • 35 Answers
$50-$150 Good to Mint Condition.
This is based on info found in "Blue Book of Gun Values".
Posted on Oct 16, 2009
Dismal mossberg 85 bolt
Like most bolt action bolts, you have to relieve the spring pressure. That means you need to pull back on the cocking knob on the back of the bolt. The bolt head will come off easily then. The bolt has to be in the exact same condition it's in when you **** the gun. Reverse to reassemble.
May 12, 2016 | Mossberg Optics
What do I need to mount a scope on a Mossberg bolt action rifle
You'll need scope mounts to fit that MODEL of Mossberg rifle and a set of rings that attaches the scope to the mounts.
Feb 18, 2015 | Mossberg Optics
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
How to remove the bolt from mossberg int'l 802 plinkster
A. Lift the bolt handle and pull the bolt to the rear of the action. Push the safety
to the "OFF" (FIRE) position (Fig. 2 ).
B. Depress the trigger fully and pull the bolt out of the receiver.
C. Release the trigger and push the safety to "ON" (SAFE) position.
join me on twitter https://twitter.com/partimeprepper
Aug 17, 2013 | Mossberg Optics
HOW DO YOU DISASSEMBLE A MOSSBERG 20 GAUGE BANTUM
Same as all Model 500's. Bolt halfway open, remove barrel, remove trigger group pin, trigger group, both shell stops, bolt carrier, bolt, lifter. Reverse to reassemble. Seriously, head to youtube and watch a video. You can go step by step with the video. The only key spot you need to watch out for is the bolt/bolt carrier when you take it apart and put it back together. The carrier will just ever so slightly clear the front of the inner rail on the receiver....and when you out it back together, put the bolt into that spot, put the forearm back on so the action bars are down next to the bolt, and then drop the bolt carrier back in to link the bolt and action bars back together. Once the cvarrier is in that perfect spot, it'll drop right into the slots. Just slide it a hair forward so the rails slightly block it in and then do the stops. Next key spot....and this is one a lot of folks mess up so don't feel bad. You aren't alone. The pins in the trigger group have to be centered all the way to get the trigger group in right. Use your fingers to center them on both sides, slip the front edges into the trigger group hole to catch the two front tabs, and then GENTLY lower the group in and pin it. DO NOT FORCE IT IN!!! Those tabs break.
Apr 19, 2013 | Mossberg Optics
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
I HAVE A 20 GAUGE BOLT ACTION AND THE CLIP IS MISSING WHERE COULD I FIND ONE MODEL 185KC.
I think this one will fit your gun , but call them first to confirm this before you order.
http://www.gunpartscorp.com/catalog/Detail.aspx?pid=68020A&catid=7772
Customer Service Information Line: (845)679-4867
Jan 21, 2011 | Mossberg Sport & Outdoor - Others
Looking to buy 5 shot mags 595/695 bolt action mossberg shotgun.
You can check this website http://www.gun-parts.com/mossberg/ Most of my friends buy their gun parts and accessories here. thanks
Jan 11, 2011 | 1&1 Soft Air Smith Wesson Mad Max...
I took out the bolt to clean it and now can't get it back in. It goes part way.
Not real sure which model you have, one named is a semi-auto, the other is a bolt action. So if you have a bolt action, to reinstall the bolt you have to have the safety off, pull the trigger as you insert the bolt back in place (be sure it is unloaded and pointed in a safe direction). If for some reason the bolt has un-cocked you must first **** the bolt. some models have the firing mech. in the bolt.
Jan 04, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
Optics Logo
445 people viewed this question
Top Mossberg Optics Experts
obsteiner
Ted Maxwell
ray gallant
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
