Question about Furuno Navnet 1964CBB/NT vx2 Radar C Map Nt
Hello there, I have a 4' radar antena with a
Hello there, I have a 4' Furuno radar antena with a 10" GPS plotter. Plotter works perfect showing heading or north up; but radar image is upside down, antena is mounted front facing foward, so I have no idea what is wrong.
Thanks for your help
    New Friend:
  • 132 Answers
Ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Posted on Jan 13, 2010
I want to do a master re-set on a Furuno Navnet 2 , 1944 radar/plotter. Do you know the sequence of keys? Andy
Press and hold the alarm key whilst powering up. Also try it with the clear key while powering up again.
Sep 05, 2010 | Furuno NavNet vx2 1944C/NT GPS Receiver
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
My Raychart won't take a fix. I've been advised
Maybe you backup batterie inside you plotter is low If yor plotter shows you that you are somewhere in Afrika on the atlantikcoast you have to change only the battery inside the plotter it kost few euro.
The next possibility is that you have problems with you extern gps antena look after broken kable or try it with another Gps antena
Oct 13, 2009 | Raymarine GPS
C120 displays NO DATA SOURCE in the radar section of the screen. ohns resistance test checked out. what else can it be?
1. you must have the latest software 4.29 the new scanner dont work with the old Software.
2. Be shure that you have really put in the connector of the cable inside the plotter its not so easy.
3.
try the plotter on an nother boat with an working system than you will know if its a problem with the antena or Plotter
Aug 06, 2009 | Raymarine C80 GPS Receiver
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Radar Displays the image upside down
If this is on the radar screen, you'll have to set your heading alignment on your radar. The radar may be 180 degrees out. if this occurs on the plotter, then if you have a heading sensor attached or an autopilot, your heading may be off.
Feb 03, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
Furuno Navnet 1964CBB/NT vx2 Radar C Map Nt Logo
166 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
