1999 Dodge Neon Logo
Posted on Oct 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 Dodge Neon rear license Plate bulb
How do you replace a 1999 Dodge Neon rear license Plate bulb?
  • 1 more comment
  • Anonymous Mar 16, 2014
    How do I take the cover off to change the plate bulb Oldsmobile Bravada 1999
    How do I take the cover off to change the plate bulb 1999 Oldsmobile Bravada
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Oct 08, 2009
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236615
Points
18738
LICENSE PLATE LAMP BULB
REMOVAL
  1. Remove screws attaching license plate lamp to rear bumper
  2. Remove lamp from bumper.
  3. Remove bulb socket from lamp.
  4. Pull bulb from socket.
INSTALLATION
  1. Install bulb into socket.
  2. Install bulb socket into lamp.
  3. Place lamp in position.
  4. Install screws attaching license plate lamp to rear bumper.
1helpful
I just purchased a 1999 Dodge Avenger, the headlights are not coming on, the license plate light also..... All my other lights work, backlights, backup lights, blinkers (front and rear), hazards........
The headlight fuses are in the cabin. Not sure where, but start looking under the dash on driver sude. The box may have a cover.
else, look for a panel cover in the pillars. The licence plate light is probably burned out, as it runs on the same circuit as the running lights.
1999 dodge caravan the parking and license plate lights won't work
Front and rear don't work, or just rear? Have you checked for voltage in the bulb sockets?
1helpful
How do I change my rear License plate light bulb on my 1999 Plymouth Voyager minivan.
If it is not possible to take the lens off from the outside. (this is the normal way on most cars) Open the tailgate and remove the whole interior panel. Its not as hard as it sounds. This should allow access.
1999 dodge Dakota all lights work new bulbs new fuses better shows all good on back the tag light doesn't work or the park lights just on back have signals back up and break ????no juice going to bulb
That makes sense since the rear taillights and license plate lamps come from the same power source, which is different that the ones for the backup and brake lights. Here are two diagrams that show the electrical path for the lights from the battery/fusebox all the way to the lamps. Hope this helps!
Hopw do I replace license plate light 2001 dodge neon
If the lens, or lenses, don't have screws then in all probability you'll need to access the lamps from inside the trunk. You'll probably have to remove some kind of trunk liner or maybe pop off some access covers to get to the bulb sockets. You'll need to remove the bulb socket(s) which may have some kind of plastic "lock" you have to press ...just take your time and look at the socket. Then again they may just twist out.
04 Dodge Stratus license plate bulb
get printout/bulb from parts store..
1helpful
I need to replace the bulbs above the license plate on my 2002 eldorado how do you replace them....get at the old bulbs
Hello: Remove the license plate, then remove the screws on the chrome piece behind the license plate and the you can access the bulbs.
4helpful
License Plate Lamp Replacement on 1999 Cadillac Eldorado ETC. Where is the access point for replacing the licence plate lamps?
Hello, remove the rear license plate, remove the housing where the license plate was mounted, now you can see how to replace the bulbs.
3helpful
2answers
License plate bulb
how to replace the Dodge durango 2004 number plate light
6helpful
2001 dodge neon tail lights inop
looking at your schematics and , you say tail lights don't work , you didn't mention if front parking lights and license plate lights are working , they all come from the same source , a black /yellow wire , a good clue if front work and rear don't , please advise .if fronts work then you have a open circuit somewhere between junction S118 (near breakout for left headlamp) and rear sockets.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
