Question about Whirlpool Ovens
Have Model RBS305PDQ6, SN XK1601117. Just tonight entered "bake" which gives heat 350--but whenever I entered up or down temp it went to 345, then 340 etc. never would go above 350. why?? help
hotuna
  • 288 Answers
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Posted on Nov 11, 2007
  • 1314 Answers
SOURCE: Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Posted on Dec 30, 2007
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    garing
    • 998 Answers
    SOURCE: Temp Control
    change temp control
    Posted on Aug 14, 2009
    jumptrout51
    • 3361 Answers
    SOURCE: F1 when bake on oven is 350 degrees.
    You also have a defective electronic control. Replace the clock.
    Posted on Aug 30, 2009
    Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
    I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
    Nov 26, 2014 | Whirlpool Ovens
    Can not raise temperature above 350
    500 degrees farenheit is 260 degrees celcius (metric)
    any chance the display is set for metric ?
    Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
    I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
    Page 22
    Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
    More here
    Aug 23, 2011 | Ovens
    I press the bake button, i choose temp Ie:350 degrees, wait until goes up to temp, next thing you know, it shows 350 but the food is not cooking. press cancel, press bake and 350, temp starts to climb from...
    More information is required make model, display type LED, or blue neon red light goes out when on temp, without more info cannot help.
    johnf1
    May 17, 2011 | Ovens
    We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
    try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
    Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
    Elements in convection oven won't heat
    DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
    http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
    It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
    P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
    Mar 04, 2009 | GE Ovens
    Oven model RBS245pd86
    after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
    Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
    Whirlpool Electric Wall Oven RBS275PDQ6
    had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
    May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Ovens Logo
    88 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
