My humax is stack in standby mode
My humax IRCI 5400X receiver is suddenly stack instandby mode. when power is switched 'on', it goes into a mode where all that appears is three blinking dots... what could be the reason, and how can it be fixed?
Shuttle83
  • 1139 Answers
SOURCE: problem for humax 5400
This is telling you of a defect in the circuitry since this unit cannot be repaired I would contact my satellite company and have the unit replaced since it is defective.
Posted on Sep 16, 2007
Gurudristi
  • 98 Answers
SOURCE: The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Posted on Mar 13, 2009
SOURCE: goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Posted on May 31, 2009
SOURCE: Power/Standby mode blinking, what is the reason?
I have a Denon AVR1708 and a Denon AVR687. Both had this issue and the issue is related to high temperature usage; like if the unit is in an entertainment systems with poor ventilation. I was able to fix both fairly easily. The issue is related to the voltage regulators on the power supply board on the 1708 and the main board on the 687. In my case, I had failures of the -15 volt regulator KIA7915PI. Both I believe were related to high temperatures.
You can get the regulator for as little as 50 cents at some online stores. The job on the 1708 was easy, however, on the 687 it was a bear. It took about 1/2 hour on the 1708 and 2 to 2 1/2 hours on the 687. The component is a lot harder to get to on the 687. The component needs to be unsoldered and removed and the new component soldered in. You will probably have to remove some caps to get go access. Thermal grease should also be applied to the new component.
Posted on Aug 30, 2009
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
I only have one scart outlet on my tv my ariel is in the wall and mthen into my tv but its just picking up tv programmes on my humax recorder and not through my tv
The aerial should first go to the Humax, then from the Humax to the TV. Make sure power-saving is turned off on the Humax, otherwise it will not pass the aerial signal to the TV when the Humax is in standby.
If ypou want to use Humax power-saving, the aerial must be split so that one feed goes to the Humax and another to the TV.
May 19, 2016 | Humax Televison & Video
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Humax has siezed up = nothing working at all
Have you tried unplugging from the mains for about 5mins.
Sep 29, 2012 | Humax FOXAT HDR DTV Receiver
How can I download the latest software upgrade for my Humax IRCI-5400. Thank you.
I HAVE HUMAX IRCI-5400 INEED CHAINAL FAIL<utube src="HUMAX IRCI-5400 CHAINAL FAIL">
Jan 02, 2010 | Humax Televison & Video
Humax PVR9300t keeps freezing, have received instructions from Humax on resetting PVR to basics which hasn't solved the problem. Is now starting to freeze during recordings.
Apparently there is a new Humax software update which will be released on 3rd March 2010 - leave your box on standby that night & hope for the best.
There are a number of us with the same problem. Curently the only solution is to power cycle the box (turn off & on again from the switch at the back)
Nov 18, 2009 | Samsung SIRS4120R Receiver
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
51 people viewed this question
 Grubhead
Grubhead
