Question about Refrigerators
Our icemaker doesn't work. We have had a problem with it ever since we purchased it. When it is working, the ice gets stuck before it gets to the ben.
    President:
  • 1,304 Answers
Ok check your ice machine for level
it is insatlled level but when the people who install the fridge put the unit in the spot most tip the unit to the back to assist in door closure this causes the ice machine to go out of level and fill improperly
Posted on Oct 08, 2009
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kitchenaid icemaker
Hi, you need to provide more details. Does the icemaker power on when its put on and doesnt make ice or it doesnt power on at all? More info is needed pls
May 05, 2013 | Kitchen Appliances - Others
Ice maker not working
Check the following:
* Water supply to the fridge
* Open the freezer compartment and check to see if the water inlet fitting is frozen. It can be thawed out with a hair dryer....carefully
* If not the above, check the water valve, usually located on the lower back of the unit behind a cover. It may be malfunctioning or is plugged with debris
* Make sure the stop arm of the ice maker (inside the freezer) isn't stuck in the up position
Apr 27, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker DOES NOT WORK.
Make sure the bale arm is up. If it is, check the rake fingers of the icemaker, they should be at about 2 oclock looking from the boxed end. If they are not in the correct position, your icemaker needs to be replaced.
Oct 06, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
