Kenmore washer model 110.91210100 bought in 1992 won't spin, goes thru the cycles but won't spin out? Is it a coupler? Is it worth fixing?
    President:
  • 1,304 Answers
If its aggitating properly it is likely the transmission and i would not reccommend reapair for that
Posted on Oct 08, 2009
Kenmore washer oil leak
That is a transmission issue. Once it starts leaking oil. The gearcase needs to be replace along with the clutch and coupler. The repair should run you about 150-250 dollars in parts. But I do believe it is worth the repair. If you are above average with tools and repair it can be done in about 30-45 mins and will allow you was to last longer than any new washer you can buy.
Apr 30, 2017 | Washing Machines
My Kenmore 11022642 model goes thru all the cycles ok, but when it gets to the spin cycle I have to give the drum a push to get it going, it will spin with very light loads. I checked the lid switch for...
The transmission in your washer is going bad. It is not creating enough power to get up to high speed without assistance. I would start looking for a new washer. The transmission is one of main parts for the washer and it will cost over 400 dollars to fix it.
Jul 11, 2011 | Kenmore 22642 Top Load Washer
I have a top loading Kenmore washer model # 22432100. It won't drain the water and spin. I completes every cycle up until then and it just stops. When I restart it, it works until draining,...
this is a direct drive washer the reason your unit is depending on if your hearing the motor running or not would either be the motor which i do not think it is or the drive coupler which connects the motor to the transmission and lets the unit spin here is also a video on how to do the repair for the drive coupler if when you disassemble you find the drive coupler intact and not broken message me back then for further diagnosis Thanks again heres you video http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler
Rick
Jun 15, 2011 | Kenmore Washing Machines
My kenmore elite washer model # 11022932100
If the pump is running and the water goes out the prblem is with the coupler or the clutch. If nothing is running the lid switch should be checked first.
Eric
Nov 22, 2009 | Washing Machines
Kenmore Washer won't spin
If the clutch spins and the transmission does not it is a bad clutch.
While you have it down replace the direct drive coupling also.
And yes, if the machine is in good condition otherwise it is worth doing the repair.
Jul 11, 2009 | Kenmore 27032
Kenmore 90 series will drain but not spin
You definitely have a broken motor coupling. This is the piece that connects the motor to the trasmission. The pump is connected directly to the motor on the other side opposite of the coupler. When they break, the water will drain but the washer will not spin.
Here is a repair manual that will help you replace the motor coupler.
If you have anymore questions please ask. This is an inexpensive repair and something you can do yourself. Just refer to the coupler in the manual and you won't have any issues.
Thanks
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
