Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator model#ED5PHE side by side ice maker will not dispense ice. Cubes stuck in the tray half pushed out, water then fills and freezes leaving cubes to large to push out..
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool is not making ice cubes and the tray is dry, no water inside the ice maker but the water dispenser is working fine.
Most likely the water control valve on the rear of the refrigerator is defective on the ice maker side. Fill the ice maker with tap water and if it dumps the ice and does not refill then the water control valve is the reason. Usually an ice maker that still had cubes and will not dump the problem would be the ice maker. Hope that helped you, Thanks, Sea Breeze
Nov 22, 2009 | Refrigerators
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Problems with ice maker
Bsbbj,
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
237 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
