during formatting ,after change all boot from devices into CDROM ,then the screen displays "press any key to boot from CD"but at that time my keyboard is not working
you need to check the connection of your keyboard if it is properly connected to the port. you can also determine this upon boot up because of the light that will flash from the keyboard. just in case you can not see those sudden flash of keyboard light you need to replace your keyboard before resuming your set up because you will need this in entering the data for your name and the serial number of your operating sytem you are installing
The drive worked ok then suddenly my main storage folder shows empty. But the drive still shows the...
(More)
The drive worked ok then suddenly my main storage folder shows empty. But the drive still shows the amount of data that there was is still present...?
I can plug in my Passport and get a window up My Passport (F) Then it says:- Always do this for...
(More)
I can plug in my Passport and get a window up My Passport (F) Then it says:- Always do this for Pictures followed by an list of actions for pictures the it says general Options 2 choices then Set Auto play in defaults.....I do not know where to start....This device was recommended as a back up drive?
my simpletech external hardrive seems to just be spinning, the red light is on on the front instead...
(More)
my simpletech external hardrive seems to just be spinning, the red light is on on the front instead of the blue light.the model # is96300-40001-00. In other words it is locked up.
