Question about Kitchen Ranges
Oven isnt getting hot enough Its like 200 degrees off. Is there a sensor or light and where is it at ? Its a J SP31GOP1WH
    President:
  • 1,304 Answers
If it is electric either one of your elements might be bad
broil or bake
some ovens use both to preheat
Posted on Oct 08, 2009
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Thermastate isnt reading right how to recalibrate
If your oven is 150 degrees out of calibration you need to replace the thermostat. More than 50 degrees and you are wasting your time trying to calibrate it, it will just drift right back out.
Feb 17, 2015 | Hobart Cn85 Half Size Electric Convection...
Oven won't pre-heat or reach bake temp?
Could be the oven thermostat, that's the long skinny tube with the thin copper pipe coming off it follow it back to the oven knob. Test it by putting a putting an oven thermometer in and compare the difference they only cost a few dollars at good home ware shops.
May 07, 2014 | Maytag MGR5751AD Gas Kitchen Range
GE JGSP31GER Gas Oven doesn't heat up hot enough
The part your talking about used to run about $275 which is pretty high for a free standing range but the cost of it isn't important. The reason why is that they no longer make that part anymore and when i looked it up I got NLA which means no longer available. You may get lucky and find a company that possibly has one still in stock, but there is no way that it will come with a warranty, so if its a dud when you get it your stuck with it. I would invest my money in something I could fix when it came time to.
Jun 19, 2012 | GE Kitchen Ranges
I have a Kenmore 362 75191893 gas range. The oven begins to heat, but doesn't even reach 200 degrees. It seems like it has been reaching lower and lower temperatures over time. Besides this new problem,...
If the burner does not light (with a huge flame above it) I would direct you to some gas line blockage.
But if the burner flame lights good and then goes out early before it's good and hot then I would direct you to a defective oven temperature sensor. The sensor is in the upper wall of the oven cavity, can be bought at your local appliance parts store, and installed by any handyman.
Dec 05, 2010 | Ovens
The oven is not getting hot enough. display says it's 350 degrees, a portable oven thermostat says it's only 250 degrees
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Jan 13, 2009 | Ovens
97 dodge ram running hot
What temp rating is the thermostat you bought ? there are 3 I believe for your truck, check this and if it is rated below 200 degrees then I would re-flush and add new anti-freeze 50/50.
Nov 05, 2008 | 1997 Dodge Ram 1500 Club Cab
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
