Question about Samsung SC-D353 Mini DV Digital Camcorder
When I try to record in Memory Card mode the camera fails
When I switch to Memory Card mode and try to record one of two things happens. Either the camera locks up after one second and doesn't allow me to change any settings, zoom, or do anything else or after one second the screen goes blank. Either way I have to turn it off and sometimes flip the switch around a few times to get it to work again.
It does occasionally work, but maybe only one time out of ten.
I'm also having image and color quality issues, but it seems to me that it's a CCD issue based on what I've read so far.
Thanks for any help you can provide,
  • 871 Answers
Reset it. if it still doesnt work.
try reformatting the card.
Posted on Jan 14, 2008
I tried contacting the Nikon tech support,infortunately they were unable to answer my question.The D5000 has a movie mode; with the camera came a 'pq1 4GB SD HC card'.According to the manual I can...
The five-minute limit has nothing to do with the memory card or the video resolution. In some parts of the world video cameras are taxed at a higher rate than still cameras. Cameras that can only record videos up to five minutes in length are not considered video cameras and thus are taxed at the lower rate.
When was the last time you saw a movie or TV scene that was five minutes long without any cuts or breaks? It doesn't happen often and very few people find the five-minute limit restrictive.
Video quality is a very subjective thing. The quality is better than that of almost all compact still and video cameras. It's not as good as professional-quality video cameras. Video has a different "feel" from film --- but which is better?
Since the recording length doesn't depend on the resolution, I'd suggest you always record at the largest resolution. Videos can always be shrunk in size --- they can't be expanded.
Aug 17, 2011 | Cameras
File failed message
The same thing happens to me when I try to record thru the "A/V in jack". It appears (my first thought) that the camera is trying to record to the internal drive and it runs out of memory really quick. But then, when I play it back, (the small 15 seconds or so) the audio and video are not sync'd. Most of the time at least. Very inconsistent. It also locked up and froze for me too. I had to remove the battery to reset it. Once or twice it recorded normal, (once when I reset the default settings and another time just out of the blue) - I thought I had it solved but it went back to "File Failed" after about 17-20 seconds of recording on the next record session.
I have the thing packed up ready to take back, but am looking for a solution so I can keep it..
Jul 26, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Problems recording onto memory card with JVC GR-D70
DUDE u can only take some stills in the memory mode. no vedio recording is available in memory mode. Thats not a problem DUDE. i got the same model.
mail me
Dec 28, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Memory Card Errors with Canon PowerShot S3
There most definitely is a solution to this problem. Follow this link for a step by step fix for the memory card error. It requires taking the camera apart but if the warranty is expired you have nothing to lose. Fix worked fine for me.
Nov 22, 2007 | Canon PowerShot S3 IS Digital Camera
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Trouble with video recording
The length of the movies you can record is dependent on both the memory you have left on the card, and the recording mode you are on. With a clean card, and on the default recording mode, your movies should go back up in length. you might be in HQ record mode while you should be on SQ for longer recording time. If all fails, try reformatting the card. Good luck, hope this helped.
Mar 28, 2006 | Olympus Stylus 400 Digital Camera
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Samsung SC-D353 Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
