Roper REX5635E Dryer
Problem for Roper REX5635E Dryer
Roper dryer takes a minute to start then shuts off
By codich on Oct 08, 2009
roper dryer takes a minute to start then shuts off 2 minutes later
Solution #1
posted on Oct 08, 2009
Not Rated)
TheMobilian
Rank: Guru  Washers & Dryers  Expert
Rating: 89%, 708 votes
his is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Was this helpful?
Yes
No
Popular Solutions for Roper REX5635E Dryer
Questions and Unsolved Problems for Roper REX5635E Dryer
Do you recommend Roper REX5635E Dryer?
Answer
Answer
I just bought a Kenmore Elite Dryer with moisture sensor. The clothes take much longer to dry than... (More)
Answer
When pushing the start button the dryer makes a humming sound and then fails to to start.
Answer
Our dryer started out by making a squeeking noise. Then when it got hot it started shutting... (More)
Answer
when i press the start button dryer comes on but does not turn
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Roper REX5635E Dryer:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
