Question about RCA Televison & Video
My RCA 52in HD Tv # D52W23 shuts off. What could be the problem?
video-tek
  • 150 Answers
SOURCE: I have a RCA HD 52in and I'm have a problem with
Hi, rca`s don`t have convergence IC`s, they use an entirely different system to perform convergence, you have a blown chemical fuse and 3-6 bad solder joints on your flyback transformer. replace fl231 chemical fuse rated at 400ma. right beside flyback (theres 3 of them your bad one is the middle one)and while your soldering re-solder all of the flyback transformer pins and your tv will be back to normal :) video-tek
Posted on Jun 05, 2009
  • 17 Answers
SOURCE: RCA 52in. Projection TV D52W19B does anyone
How do you know the flyback is bad
Posted on Sep 01, 2009
asnowman
  • 788 Answers
SOURCE: 52" rca hd proj. tv model # d52w23
Your symptom sounds like a damaged convergence IC, whick you have found to be true.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sink2.gif compound that is on the heat sink2.gif, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 04, 2009
tlm931
  • 273 Answers
SOURCE: I have an RCA D52W23 TV convergence problem
bd pt no is 264103 check your local rca dist and servicers
Posted on Oct 24, 2009
Testimonial: "What a great site this is to get answers to questions very quickly. Thanks!!!"
Slinteriors
  • 8617 Answers
SOURCE: My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Posted on Apr 02, 2010
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
We have a RCA D52w23 rear projection tv that powers off.
most likley the deflection board is at issue. Thats the number one board which fails in that chassis.
Mar 15, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA D52W23 won't turn on
The set is in shut down mode due to a fault detected in power supply/vertical or horizontal deflection circuits.
The common problems with this model that will cause the symptom you describe are bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders especially under flyback area.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned, otherwise it's best to seek a qualified RCA tech for an estimate/service call.
Reply to this post if you need more advice.
Dec 08, 2009 | RCA D52W23 52" HDTV CRT TV
POWERS OFF
CP150, CP114 and CP120 Capacitor repair kit at www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions.
Nov 03, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 convergence chip
THERE is no convergence ICs on these sets it does have convergence board it has serveral ALuminnin heat sinks on it If comcast was at fault it would have fried your SSB board which will shut TV down Cost of Board is 352.00
Feb 13, 2009 | RCA D52W23 52" HDTV CRT TV
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
