Question about HP Photosmart C4180 All-In-One InkJet Printer
The printer only prints one line of jibberish. I tried reloading the driver but no help
    Scholar:
  • 121 Answers
Completely uninstall the printer in Add/Remove Hardware option in Control Panel.
Unplug printer from the computer.
Unplug printer from power source for approximately 15 minutes to clear printer's cache memory.
Reboot your computer.
Then, follow the printer manufacturer's instructions and do a fresh install of the software for your printer.
This should solve your problem.
Posted on Oct 08, 2009
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
My HP 960c won't stop printing. I get mostly blank sheets with jibberish at the top, but it's continuous.
Turn off the printer. On the computer in the lower right by the time, there should be a printer icon, double click it. This will open the print que. Select all documents in the printer que and delete or cancle them. You may have to reboot the computer for this to clear completely. Once the que is clear, turn the printer back on. Do a test print to the printer and see if the issue is cleared up. If not you may need to reload your print drivers.
Hope this helps you
Dec 16, 2011 | HP DeskJet 960c InkJet Printer
725 printer prints constanty on its own when not called for
If it's printing jibberish or "ASCII Garbage" then you probably have the wrong print driver installed.
Uninstall the print driver, disconnect the printer, reboot and reinstall the driver plugging the printer back into the PC when the installation software prompts you to.
Mar 12, 2011 | Dell 725 InkJet Printer
When i print out a paper, there is a black line through the print out.
I am assuming your black line is printed (not smudged ink)...
If your printer is also scanner/copier, try copying a page (rather than printing from computer).
If it scans & prints ok, it could be communication/driver problem. Try reloading the drivers and see if it improves. If the black line is there when copying as well, there's probably not much you can do about it.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Brother Office Equipment & Supplies
Printer is printing jibberish on not working on test prints
If you can print to it the network setup is ok. It sounds more like a print driver problem.
Aug 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Hp Photosmart c4280 Printing Jibberish, dirvers reinstalled.
You can go to HP's solution center and download a utility that will upgrade the "firmware" of the printer. If the upgraded firmware does nothing to fix it, it is e-waste.
Jul 15, 2009 | HP PhotoSmart C4280 Laser Printer
Prints, but jibberish
This souds like a printer driver problem.
Go to Strat ,Control Panel and then printers.
Delete the current printer ,reboot and windows will reinstall it.
Try printing again
Jun 09, 2009 | HP DeskJet 932c InkJet Printer
HP printer will only print jibberish!
Turn the printer off then uninstall the printer software, reboot the computer the reinstall the software. Your printer will be good to go.
Mar 03, 2009 | HP DeskJet 5550 InkJet Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
