Question about Husqvarna Chain Saw 20" Bar
After running for about a half hour or so it begins to stall in between cuts . . should i adjust the low,high or idle screw
    Brigadier General:
  • 4,088 Answers
Is the chain being properly oiled? You should get a thin line of oil after running the tip of the saw near to a piece of paper or cardboard for moment or two. Is the saw getting overly hot after running? Clean the cylinder and air passages with compressed air if it is. Check the muffler for any plugging of spark arrestor screen. Turn both jet screws CW to stops (lightly) then turn both out 1-1/2 turns CCW for a basic setting. Pull throttle full on (after warm up) and adjust H for high engine speed, but 4-stroking that smooths out immediately when cutting. Release throttle and adjust L for fairly smooth idle, but rich enough to allow the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops moving. Hope this helps.
Posted on Oct 08, 2009
  • drallim Oct 08, 2009
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
How many turns out is the High and Low screws suppose to be adjusted. Also how many turns out is the larger idle screw suppose to be.
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Before adjusting anything, check the fuel filter, air filter and muffler for plugging. Start the engine and allow to warm up. Pull the throttle full on and adjust H needle CW until the engine begins to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to idle. Hope this helps!
Jul 11, 2010 | Husqvarna Chain Saw Handle Models 50 51...
On the husqvarna se266 carborater, what is the low and high screw settings or how many turns is the screws supposed to be at?
Initial setting for a Husqvarna; "H" and "L" screws at 1 turn CCW form lightly seated. Then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 22, 2010 | Garden
I have a stihl FS88 line trimmer. Ran it about half an hour then it stalled.Messed with the carb screws(all 3).Where do I start in adjusting the screws? Cheers
start at 1 and a quarter turns out from closed position one is marked l for low speed the other is marked h for high speed no 3 is the idle adjustment
Jul 08, 2009 | Garden
Idle run mixture controls
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 08, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a newer model Husquarna chainsaw. When I give it extra gas it stalls in the sweet spot. If I give it max gas it cuts off. When I try to saw it wants to cut off also. I changed the gas and tried that...
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn. If you have to change the high rpm jet a lot you might have to go back and readjust the low rpm jet again and set the idle speed. Never idle it high enough that the chain turns while at idle.
We used to have to do this a lot in timber business. You go up on the mountain to cut logs and the altitude has high enough that you had to adjust carburetor and then do it again when you got back to the sawmill.
Jun 04, 2009 | Husqvarna Chain Saw 20" Bar
Craftsman 16'' chainsaw, start with very high rpm, how to adjust ?
The H is for when your cutting,it keeps the saw from stalling. The L, is for the saw when at Idle. When the L ,is adjusted right, the saw should stay running ,and the chain should not move ,that is with the break in the off position. The H screw,should be adjusted if the saw bogs down when rev ed up. A good starting point for theses screws would be a turn and one half out.
Jan 19, 2009 | Garden
Need high and low ajustment procedure
Hi carlayoung
Start the engine and turn the high speed screw "H" in(clockwise)until the engine starts to slow down(the fuel mixture is to lean,not enough gas).
Slowly turn the screw out(counterclockwise)until the engine begins to run smoothly,keep going very slowly until the engines just begins to run rough again(rich condition,watch for black smoke from exhaust).
Then turn the screw in again(clockwise) to a point about half way between lean and rich condition.This is the properly setting.
The low speed screw"L" adjust in the same manner.
The idle speed "T"adjust accordingly.
best regards savumihai71
Dec 14, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Husqvarna Chain Saw 20" Bar Logo
378 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
