Question about KitchenAid KSRG25FKSS Side by Side Refrigerator
Clicking from underneath
Every few minutes there is a click from underneath the refrigerator. then after a few seconds it clicks again. it sounds like a small relay closing, and then opening/kicking out. starting to lose cooling as well.
fins were very dusty, cleaned those off. problem continues to persist.
  • geerbox70 Oct 08, 2009
    should i disconnect unit until i can fix problem?
    can other damage be done, or is it just not turning compressor on?
    President:
  • 1,304 Answers
You need a new relay and overload on the com pressor
goto www3.sears.com type in your model number
look for compressor or controls
on the compressor itself you will see the overload box
you might need both the relay and overload id replace both anyway
Posted on Oct 08, 2009
  • milten1
    milten1 Oct 08, 2009
    yes i would disconnect
    it could burn the internal relay
    not a promise but good to error on the side of caution
Kenmore elite refrigerator, both are "luke warm"
Sounds like your start relay/capacitor is fubar. The clicking is caused by the Klixon shutting down power to the compressor when it does not start properly. When it cools it resupplies power only to overheat and click when it shuts down again.
Jun 12, 2017 | Refrigerators
My refrigerator is a Kitchenaid KSRG25FKSS05 and still runs but not cooling. I hear some kind of relay click and then click again after about 10 seconds. Then I don't hear it click again for a few minutes....
refergerant is not causing this problem. when the comp starts up and the bottom fan also starts up and the fan in the freezer comes on / this alll happens whe the cold control said we need more cold . so it sounds like the one that won't come on is the comp . and the clicking noise is the thermal control shutting down. then when cooling tryes to restart. . the kit you need is 8201786 this is called a start device and comes with instructions .. cost about $70.00 . easy to install . mm hope this helped and thanks for the model # .. and for ysing fix ya ..mm feed back pls
Nov 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
199 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
