Monitor has power, but screen will flash on and then turn off
  • 81 Answers
Connect the monitor with a diff computer> if it happens again> try and do a factory reset from the front panel menu
Posted on Oct 08, 2009
When turned on - green power light comes on then screen momentarily flashes - very quick flashes every second or so.
Are you getting any video on the screen? I would make sure the power cord in the back of the monitor is securely seated. Make sure the video cable from the monitor to your desktop is screwed in tight as well.
Hope that helps
Proteus
Nov 17, 2009 | Videoseven L17PS 17" LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
OSD Lockout bananas
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 23, 2009 | HP w1907 LCD Monitor
Monitor flashing at startup
When the monitor is flashing, is the flashing coming from the middle and going up and done to fill the screen. If so, probably capacitors in the monitors power supply are leaking and need replacing.
Mar 27, 2009 | ViewSonic VG900b 19" LCD Monitor
Monitor flashes
If the power button flashes, You probably have a bad power-inverter board thats needs to be refurbished due to burned out capacitors and possibly a transistor or two.
If the screen flashes and the power button stays steady, it could be the same thing or a bad bulb in the screen.
Fran
Sep 30, 2008 | Gateway FPD1975W 19" LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
