Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I have the 50" SXRD XBR1 grand Wega; This has been a great set for 3+ yrs. A flashing red light promted me to replace my original buld (this site). I now still have a flashing red "power" light, shuts off (light comes on, goes off, flashes four times, shuts down. After 3 times, the TV will work)! HELP! ballast? What can it be?
Its the fan that cools the bulb. Try turning on the tv and look at the fan to the rear of the bulb. If the fan is not spinning that is your prblem. The tv has a safety switch that will cut off the tv if the bulb gets too hot. I was able to tap my fan with a pencil and get it spinning, but that is just a temperary fix. After a while, you will find the fan will stop working all together and it will need to be replaced.
Posted on Oct 08, 2009
Flashing red light no picture and a buzzing sound
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jul 24, 2014 | Sony XL-5100 Projector Lamp for Grand WEGA...
The red lamp light on my Sony Wega SXRD flashes 5 times 2-3 times in a row then shuts off. No picture or sound
This usually indicates a problem with the main board on the TV. This board is similar to the motherboard in a computer. I would have a repair professional look at it to confirm my suspicion. However, I will warn you that if it is the main board, it is generally more economical to simply purchase a new TV.
Oct 19, 2012 | Sony Grand Wega 50 in. Diagonal Class Full...
Changed lamp and fan and still have a flashing red light
changed my lamp on my 50"grand Vega and got one or two flashing red LEDs
forgot to put the lamp cover back tried again everything is fine now thank god,
Jul 19, 2012 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
How to FIX
Televisions have protection circuits which prevent full power-on if a fault is detected in a high voltage/high current circuit such as the backlight inverter.
Some googling on 'Sony Blink Codes' found that 4 blinks is 'backlight failure'. A common failure in LCD displays is the backlight inverter board which is a transformer similar in function to a fluorescent light ballast, as the backlights are fluorescent lamps.
If the screen color is getting pinkish/reddish, that's a sign that one or more of the lamps themselves are going bad.
Since multiple lamps are connected to (typically) two inverter boards (a primary and secondary board), I am fairly certain that the blink code refers to a failed inverter board and not a failed lamp.
Oct 19, 2009 | Televison & Video
How do I take the tv a part to replace the lamp
what model is it. if it is an sxrd then there is a small panel on the right side (looking at the tv) with a screw holding it in place. remove the screw and panel and pull the buld out using the handle on the buld housing
Jun 11, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
50" sony wega blinks red at intervals of 3
The light is flashing an error code to you telling you what the problem is with the set. Either refer to your handbook or go to the Sony website to find out what the error code means. Hope this helps.
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
248 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
