Question about Frigidaire FEF326 Electric Kitchen Range
The surface indicator light on my 27" GE drop-in range flickers and the back element sometimes gets warm when the dial is on "off"
    President:
  • 1,304 Answers
Your having an issue with the selector
sounds like it is allowing trickle voltage bypass
Posted on Oct 08, 2009
Maytag gemini model #mer6755acw on indicaror light on account front right burner is still on low but dial is off ... what up
You have a bad infinite switch for that element on the back of the switch you should have terminals marked L1 H1 L2 H2 and P when switch is on contacts close between L1 and H1 and P P sends power to light ,L2 and H2 in the off position these contact points should read open
Feb 20, 2015 | Maytag MER6755AAW Freestanding Smoothtop...
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
I dropped a jar on the ceramic cooktop now the hot surface light will not go off
Each element contains a sensor that activates an attached switch to the hot indicator light. The shock of the dropping jar may have damaged the switch.The associated element will have to be replaced.
Mar 06, 2012 | Amana ACF4265AS Electric Kitchen Range
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Hot surface indicator light won't turn off
The element contains a sensor to detect when the element is hot, these sensors fail. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
May 09, 2008 | Kitchen Ranges
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire FEF326 Electric Kitchen Range Logo
112 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
