The power went out today. Once the power was restored, the green (Timer) light simply keeps flashing and the TV wont turn back on. None of the buttons on the front of the TV work nor does the remote. I have tried other outlets I have tried the reset Any other ideas ?
  • tomwix Oct 09, 2009
    Mistubishi - 55 inch rear projection - bought back in 2002 1080hd
  • Lavell Turner
    Lavell Turner May 11, 2010
    What is the make and model of your set?
    Genius:
  • 1,112 Answers
There are 7 capacitors that need replacing in you digital module, it is located on the left hand side facing the back of the set. After opening the module there is a small power board inside, replace all 1000uf 16volt capaictors with 680uf 16volt capaictors. After replacing them there will be a small green led on the board that lights inside the digital unit. it will flash then go steady if all is ok with the set after replacing these capacitors. After this is done the power light up front will blink about 30 secs then go off. Turn on the television and happy viewing...
Please leave comment...
Posted on Oct 10, 2009
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Once the current went out in our residence, the tv went out as well. When the current was restored, the tv didn't come back on by the remote or pushing the power button on the tv itself. Where the green...
Although you may think the power outage has ruined your TV, it has not. I have repaired this model . This model by now has several bad grounds. The worst case is in your convergence board. This problem was in the process before the power outage. I do not believe you will have to purchase parts for this particular model. If you can very carefully pull out the convergence board, you will find 15 or twenty bad solder grounds on the solder side of this board. The major concern will be that the convergence IC, which is a STK-393-110 has separated pins from the board. This would be the first thing to solder. Next the jumper jack cables that connect this board to the other two boards will have bad grounds as well. You must really,really have good eyes to see the cracked rings around the pins of any and all ICs,resistors,transistors, capacitors, diodes etc. This will restore the operation of your TV. I must tell you...it will not be easy to pull this board out and replace. You may opt to see a TV tech. Show a tech this info. This will repair this TV. Thanks for asking and show a few hands of support!
Feb 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Tv wont turn on
Green light of death, capacitors have to be replaced but it probably wont fix it anyways. Once this happens the TV is completely useless.
Jul 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The power went out tonight and now the TV wont turn on. When the power went out the TV was off. I have tried reseting the TV several time to no avail. The green timer light just keeps flashing. Any ideas...
Either the capacitors are shot or the high-voltage transformer aka power supply is shot. You can test power from transformer to main board with a voltmeter. you can test the resistance/continuity of any capacitor with a mulit-meter in the ohm position.
Feb 02, 2010 | Televison & Video
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Dec 30, 2007 | Televison & Video
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
