Question about Harman Kardon HK19.5 Computer Speakers
Sound problems O.k. I have some static coming from my speakers but it will not play a cd or any sound. I can only hear a small static sound. This sound is constant it doesn't waver or produce any other sound even when I put in a cd.
  • lindsaym41 Sep 15, 2008
    I just brought my old harman/kardon computer speakers from home & plugged them into my Dell office computer, & they aren't working, only making a static noise. I haven't used them in years, but the last time I did use them they were working fine. I have no idea what model they are, as they were purchased back in 1999 or 2000. I just plugged them in & thought they would work, but they're not. Is their anything I can do?
  • HESHA LISHA Dec 19, 2008
    I HAD THESE SPEAKERS FOR ABOUT 10 YEARS AND ONCE I MOVED THEM FROMONE DESK TO THE OTHER THEY STOP WORKING THEY WILL TURN ON WHEN YOU TURN THE VOLUME KNOBS YOU CAN HEARTHE STATIC BUT NO SOUND.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Happy Holidays amorr36
Well, I have those speakers sometime, and they has problems with static too, and inside board failure. Time to replace them.
I suggest a new pair of sound blasters, or any other brand!
happy time
Posted on Dec 26, 2007
  • 70 Answers
Are you sure you have plugged in the speakers properly? maybe u inserted the cable in the wrong port or u just didnt insert the cable property. A loose connection can cause static and obviously it wont play anything. Please check.
Posted on Dec 25, 2007
Static coming from speakers
Not much information here but I will try my best, could be a problem with the cable your using between the speakers and the mp3 player, you could have a dry joint, if it's like a "hum" sound your getting it's a bad ground, without the mp3 playing plugged in tap the end of the stereo minijack cable with the speakers turned up? hear the 50hz buzz - if the interference sounds the same it's most likely a bad cable or bad connector on the speakers. I would need to either hear the interference to determine what fault it is or if you can describe it better i.e. what it sounds like.
Mar 31, 2014 | Altec Lansing Multimedia Computer Speakers
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
I have a Static noise coming from the right channel of my mixer. I hear it coming out the right speaker as well as the right ear of my headphones (jack). How can I fix this?
That sounds like a bad connection but it can also indicate your mixer has a problem. If it occurs on all channels it is the mixer, if only one then the problem is in the input. Check your cables, they are a big culprut in problems like this.
Jan 08, 2013 | Stanton SA-5 DJ Mixer
Static sound
Try a CD cleaning kit and follow instructions if this fails it is more cost effective to replace the CD changer than have it repaired.
Apr 05, 2012 | Sony CDP-CE275 5-Disc CD Changer
Sound problems
panasonic sa th-440 f61
Aug 18, 2009 | Venturer STS152 System
Static from speaker
Try playing around on the volume control panel. The pan might have been played with, along with other things.
Feb 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
Aug 17, 2008 | Kenwood KDC-2011S CD Player
Harman Kardon HK19.5 Computer Speakers Logo
430 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
