Question about Samsung SMH7174BC Microwave Oven
Mircowave not heating - Samsung SMH7174BC Microwave Oven
  • qabaniso Feb 18, 2008
    All functions work very well except it not heat and glass plate will not rotate
  • Samsung Master
  • 9,098 Answers
If when you try to microwave, the turntable does not heat, that's usually a bad door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 06, 2008
Mircowave heats propperly, but clock goes blank
Possible fault with your timer controller unit processor board. In many cases insects can cause secretion and so the clock circuit can malfunction. remove the unit and use a air cleaning. heat the board if there is presence of moisture.
Apr 09, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
I have a kenmore toastwave microwave. The mircowave will not heat however the toast part is functional
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | Kenmore Microwave Ovens
Mircowave oven is not heating
heatman101
Jul 26, 2011 | Microwave Ovens
GE spacemaker mircowave not heating- all else works ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My ge mircowave will nt heat anything , it run but will not heat, is there a easy fix.
you need to replace the magnetron, but i dont think this is easy
Dec 05, 2010 | Microwave Ovens
My onn microwave will not heat will it be thermostat?
No, the mircowave chip has failed, You will need to take it to an appliance repair shop, or buy a new microwave
Aug 04, 2009 | LG LTM9000 Microwave Oven
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
If we close the mircowave door the units start to run by itself. - it will not heat, but the light comes on and the turntable rotates it will not stop until we turn the power off - when power is turned...
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Jun 24, 2008 | LG Microwave Ovens
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Microwave Ovens Logo
206 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
