Question about Canon imageCLASS D880 All-In-One Laser Printer
Paper jam in front roller of imageclass D880 (about 1/3 inside)
  • 56 Answers
Dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Posted on Oct 09, 2009
How do you take out a paper jam canon ImageCLASS D320?
First you have to know the position of the paper that has jamed.
the cardinal thing to do is to loosen and open doors that must be opened in order to have a clear view of the paper.
How to open see the marks on the machine. Mainly the paper jams between the drum and the fuser, so make sure you see any green nobs meant for seperating the presssure roller and the upper roller so that the paper is free to move out in case it jamed between the fixing rollers.
See the manual on how to remove paper jams.
Jul 12, 2011 | Canon imageCLASS D320 Digital Copier
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Canon imageCLASS MF4350d paper jams
can you be specific, where does paper jams occures?
If in adf, try to clean the adf pickup rollers, if in cassette, open the printer and remove the toner cartridge, now you are able to see the pick up roller from the cassette and clean him with alcohol or water.
Hope that helps!
Jun 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Paper jam!! gets caught in roller! help please!!
Remove jam, again. soft damp cloth, gentle wipe rollers at front, no hard pressure.
Continual jams usually are the result of purchasing cheap paper, I used to do the same, learn't lesson, only a few pence more, saves all the swearing and hassle of fiddling around with jams when you have more important things to be do?
Further tip, before placing quantity of paper in tray, holding paper firmly, twist in opps directions, this helps seperate the sheets of paper that may stuck together.
Nov 12, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper has jammed and , also i am not able to see it also
Open all access doors to see the jammed paper. Also, look for tiny paper shreds that might be blocking the sensor or got stuck between the rollers. If you have a canned air, open all access doors and try to blast some of it inside.
Oct 01, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS D880 All-In-One Laser Printer Logo
334 people viewed this question
old marine
old marine
