Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
No remote but when i key in code or push inside button goes down but comes back up
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit. Tweak them a little.
Posted on Oct 14, 2009
Garage door will not go up using remote or keypad only with wired unit inside garage. Batteries were changed in remote and keypad.
You need to reset the remote units. There should be a button on the overhead unit that operates the door opener that will tell you what to do. To set my key pad I push the button and punch in my code then it flashes three times then I push the button on the opener again and the door will go up or down. You do the same with the car remote as well.
Sep 10, 2017 | Building Materials
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept book..here it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
QuantumFx Rem-200 remote codes for philip TV no set up button
Hold down the tv button and then press and hold down the power key untill the light comes back on then press and release the power key untill tv comes on or goes off then press the (dvd) stop key and it is programed
Aug 25, 2012 | Universal Remote Control URC-200 LCD...
Remote does not open or close garage door; inside button flashes
What has happened is that you electric eyes are blocked or have gone out. The eyes are at the garage door about a foot of the ground on both sides. There should be a red or green light on one of them. If not some thing is blocking the beam that goes across the door. It is a safety beam so kids can nt get hurt when the door is coming down. If the beam is broke the door will go back up.
Jan 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Key board button has come off
In most cases its as easy as centering the button back where it goes and pressing down on it until it snaps back into place. If on the first push it doesn't click back in the try pushing down and wiggling the key back and forth a little as you push.
Nov 02, 2008 | Acer Computers & Internet
Program for my tv
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Oct 11, 2007 | RCA RCR412C Remote Control
Setting it uo
Sep 25, 2007 | RCA RCR412C Remote Control
Rca412c
THIS WORK!!!!! to make this simpler
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
66 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
