Question about Arris WR850G Router (DHWR850G)
Hi i need to set up pasword for my router wr850g
    President:
  • 414 Answers
Default username and password are
username: admin
password: password
Posted on Oct 08, 2009
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Secure motorola router WR850G
If you want set wireless router with connect your internet, in that case you should secure your wireless router.The router transmits and receives data from the modem and computers connected to the network....read more: how to secure your router
Aug 28, 2012 | Arris WR850G Router (DHWR850G)
I installed a motorola wr850g and messed up. I cann't reach it using 192.168.10.1 and I can't remember the network authentication information. I reset the router using pushing the reset for 30...
This thread might help you:
http://marasingha.blogspot.com/2006/07/how-to-log-in-to-your-motorola-wr850g.html
If the reset button doesn't work and you can't reach the Router GUI through the address it has given then it could be a faulty router.
The number is listed on that thread and I do think you have the same problem.
This other link is for the router's manual incase you need it: http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_6.1.4_Rel_Notes.pdf
hope this helps!
Aug 29, 2011 | Arris WR850G Router (DHWR850G)
I forgot my password and i cant let my friends use this line
If you forgot the password, resetting the router will allow you to access the router's configuration screen again. However, this will reset the settings to default, and you will have to reconfigure the router.
To reset the router to the factory defaults, press and hold the Reset button for more than five seconds. This clears the router's user settings, including User ID, Password, IP Address, and Subnet mask.
Here is the instruction manual for the WR850G Router (the above instructions are from page 1-8):
Apr 11, 2011 | Arris WR850G Router (DHWR850G)
Hi i have the motolora router wr850g and im trying to reset it. but i dont know my password. what do i do?
If you want to reset your router, hold down the reset button on the back of the router for 30sec (this will wipe ALL of your settings). Now that it's reset, your login information is back to the defaults which is admin for your Username and motorola for your Password. If you never setup a password or username before, then this is already (or rather, it still is) your login information. Hope this helps.
Dec 13, 2010 | Arris WR850G Router (DHWR850G)
Cannot connect to motorola wr850g router
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 03, 2010 | Arris WR850G Router (DHWR850G)
Hi, whenever i reset my router to make changes
The first thing is that , you don't need to reset the router to make any changes.
When you reset the router, it comes back to the factory default settings. you will need to reconfigure the router.
If you want to make any changes on the router, do not reset the router. Simply open the set up interface of the router and make changes there.
Click Here to know more about how to open the set up interface of router
Oct 28, 2009 | Arris WR850G Router (DHWR850G)
Laptop sees the wireless network and connects, but then indicates that there is little or no connectivity. Help
this mostly happens when the router has been configured to block certain devices. take a look at the wifi config, look for IP-filtering or MAC filtering. you should see tables containing letters and numbers. make sure this table is empty
Jun 24, 2009 | Arris WR850G Router (DHWR850G)
Wr850g cant connect to xbox live
I posted a solution under a different problem, but similar. Basically you will need to pick a static IP for your xbox. Then set that IP address in the router web config >> routing >> DMZ IP address setting. Restart both router and xbox and bingo. Your xbox is now directly connected to your cable modem without the router problems preventing connectivity.
Jun 19, 2009 | Arris WR850GP Router
Arris WR850G Router (DHWR850G) Logo
138 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
