Question about Shimano Cycling
When I spin the rear wheel(when the bike is on a work stand) I can hear and see that the wheel does not spin freely, or spin for a very long time, it is as though it is hitting something that is slowing the wheel and eventually making it stop.
  • 484 Answers
First, make sure that the brakes are not dragging the wheel to a halt. If that is not it, then try loosening the axle nut or quick-release very slightly to see if the problem was an over-tightened axle (unlikely). If neither of these two are the culprit, your hub needs adjustment or repair. If you have adequate hub tools, parktool.com/repair has instructions on hub service.
Hope this helps,
matt
Posted on Oct 08, 2009
Rear wheel does not spin freely
Sounds like it has drawn tight due to a loose locknut. The bearing cones will need adjusted again.
Apr 05, 2014 | Glide Bikes Go Glider
Tip
HOW TO EASILY OIL A MOTORCYCLE CHAIN WITH NO MAIN STAND
If there is no main stand on your motorbike it can be a problem sometimes, not only do side stands dig into soft ground & warm tarmac they also make it awkward to oil the drive chain !
A simple way around this is to get either :-
A piece of strong piece of wood about an inch square ( or in diameter) or
A strong hammer or mallet or
A small trolley jack handle or similar preferably with rubber or taped ends
Whatever you use it must be about an inch (or more) longer than from the ground to the right hand end of the rear spindle (axle) or underside of the right hand swinging arm, WHILE THE BIKE LEANS on its side stand: For the very few bikes that have a side stand on the right, read left hand end of rear spindle
All you have to do is raise the rear wheel slightly by pivoting the weight of the bike on its front wheel & side stand
On medium to large bikes this means getting someone else to position themself on the side stand side of the bike, where they should put 1 foot against the side stand & reach over the bike to grab a good purchase point near the rear wheel, grab the nearest handlebar end with the other hand & pivot the bike forwards on its front wheel & side stand
This will lift the rear wheel a few inches so that your prop can be placed upright between the ground & your selected point on the bike
Spin the rear wheel by hand whilst applying non fling chain lubrication to both edges of your bikes chain
SIMPLE
EFFECTIVE
NO NEED TO CARRY A PADDOCK STAND IN YOUR RUCKSACK
Ride safe
Bike-Doc
I hope this helps (if so give good feedback please)
on Apr 27, 2010 | Motorcycles
Rear brakes keep failing.
After reading your description, two ideas come to mind. If you have bench tested your master cylinder and it does not leak down. You have checked all fittings, lines, and master cylinder for leaks, and there are none. Then would suspect an issue with the rear brake caliper. You mentioned that you replaced the rear rotor due to it warping. I am curious to know why it warped? Raise the rear wheel off of the ground and spin the wheel. It should spin freely. Then apply and release the brake, to that wheel (a few times). After releasing the brakes, spin the wheel again. Does the wheel still spin freely? If it doesn't then I would check the brake pedal (see if it is releasing freely or binding), check the brake lines (see if there are and defects, flat spots, or kinks), and check the rear brake caliper (do all the cylinders retract with little resistance?) If the wheel does spin freely then I would check to see if you are using the correct type of brake fluid. Most bikes will require you to use DOT 4 or 5 brake fluid. If you substitute for a cheaper grade, it will affect the braking system. It may sound silly but I would double check that you are not accidentally resting you foot on the brake pedal. If that was happening, it would cause the brakes to fade. I hope that helps but If you have other details or question, let me know.
Feb 28, 2014 | 2001 Harley Davidson FLHTCUI Electra Glide...
2006 honda crf100- Clutch drags when the I pull in the clutch lever. While bike is in neutral rear wheel spins freely. While still in neutral and rear wheel is spinning I pull the clutch lever and the...
The first thing you'll need to do is relax the tension in your clutch cable. Then adjust it n see if it works.your cable must be the problem.try taking it out and sork it in some oil n try freely moving it put back n see if it works
Dec 04, 2013 | Motorcycles
Kawasaki vulcan won't shift into upper gears above neutral.
Broken selector claw spring
Ride Safe
Bike-Doc
Jan 31, 2012 | kawasaki Motorcycles
No brakes at rear wheel of my 2005 standard goldwing. Had a new rear tire(screw/nail) put on and the service man told me.I normally slow down slow enough to use front brakes.I had installed full foot...
Try putting the bike on the center stand and get the front wheel off the ground with a floor jack. Spin the front wheel by hand and press on the rear brake pedal. The front wheel should stop. Likewise with the bike on the center stand and the rear wheel off the ground you should be able to lock the rear wheel with the foot pedal. On many Goldwings the rear pedal also operates one front disc. This is for people that refuse to use there front brakes to stop or slow there bike (80% to 90% of your stopping power is the front brake). Try bleeding the entire system front and back, you may just have air in the system. If the rear brake still does not work you may have a bad delay valve in the system. If you need to take the bike in to a shop, try to find a mechanic that is familiar with the system so they do not replace parts unnecessarily. That way you minimize your shop time and maximize your riding time.
Aug 21, 2010 | 2005 Honda GL 1800 Gold Wing
Pedals spin wheel doesn't turn
Bottom brackets just connect the cranks to the bike and keep the drivetrain aligned while you wail on the pedals.
I assume you mean the rear wheel spins freely when you pedal after a coast or stop. That would be the pawls in the rear cassette, freewheel or axle failing to engage. When you coast, the whirring, clicking sound you would hear is the pawls gliding over the detents. When you apply forward torque, they drop into the detents and provide drive. Like a ratchet.
Have a shop look at it. Don't ride the bike if it's going to do that. You may stand up and stomp on the pedals and have it let go and wake up with a broken jaw because you went over the handlebars, if you survive being run over. The rear wheel and drive components are not beginner bike mechanics.
You don't say what kind of drive it is.
Feb 05, 2010 | Cycling
Drive problem
check your cluch cable it may be sticking up also check you have free play on this cable,, put the bike on its center stand and spin the rear wheel with the bike in gear holding the cluch in as you spin the wheel if it spins ok the cluch is letting go
Jan 23, 2010 | 2007 kawasaki ZX-6R
Rear wheel problem on Raleigh X1 mountain bike
Three things come to mind when I read your question. First is the rear wheel bearings. Spin the wheel back and forth while holding onto it. See if you can feel any vibration or a rough feel in the wheel. I would think that if it were the wheel bearings you would hear or feel a grinding noise when you are riding.
If your rear wheel has a nut on both sides and you tightened them and that didn't work this means you must have the quick release system. You can tighten this by unclipping the wheel. Then hold the side that has the quick release lever. Hold onto the lever itself. Then turn the other end a little bit clockwise. Then put your wheel back on the bike and reclip the lever. It should now feel tighter. You may have to readjust the quick release lever a few times until you find the desired tightness.
Lastly the problem could be that your frame is worn out or broken somewhere. This would only show up when you are out riding because of your body weight and the strain put on the frame while you are pedalling. Also the part of the frame where your rear wheel sets may be chewed up. This would cause the wheel to never really tighten on the frame and could also cause the rear wheel to move.
I had a bike where the quick release wheel stystem went bad and it would not tighten on the frame. I believe the rod that went through the middle of the wheel hub was stretched and would just not tighten onto the frame.
I hope this has been helpful
Mar 17, 2009 | Crank Brothers Joplin Adjustable Seatpost...
Rear wheel not running smoothly.
Thank you for using fixya, the problem that you are encountering may be attributed to the freewheel (rear) or the hub to axle assembly on both front and rear.
Im currently using a Haro Flightline and used a few. When this kind of problem occurs, you may want to focus on the following:
crank set: remove the chain and check if it rolls freely, if not, try to open the case and look out for broken ball bearings or misalligned parts, then lubricate it.
Rear wheel assembly: remove the chain and the whole assembly from the bike, then check if it rolls freely. If not, same method, check the bearings and the freewheel. allign and lubricate it.
Jan 04, 2009 | Huffy 12 in. Girls Disney Princess Single...
Cycling Logo
134 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
