Question about Radio Communications
Radio was dropped now the channel indicator is not working no way to tell what channel it's on. its a uniden pc68xl is there a resistor or something to check?
  • 141 Answers
Unfortunately, that requires surgery :-(
It'll be much easier to just buy a new one
Posted on Jan 30, 2010
    Guru:
  • 773 Answers
If your lucky, its just the display that is broke. You can buy a replacement on ebay cheap. If its not that, you may have broke something else and you would have to trace it. It would need a tech.
If its still working other wise, just find channel 19. Go near a big highway and check all the channels until you find a lot of truckers talking. Then ask them if its 19. once you find 19, make a mark on the dial and on the radio face in the same spot. then when you put the marks together, you will be on 19. then you can just count up and down.
Each spot on the dial is a specific channel.
the other things to check. If you haven't test transmit on the radio, and just put power to it to see if it still worked, check (if it has them) either the cb/pa switch, and make sure its on CB, because some radio's when you go to pa the meter shuts off, and if you have it check the wx/cb switch. this is for weather. Make sure its on cb again, because again, sometimes this turns off the channel display.
If you haven't hooked it all the way up yet and just to power, you may have over looked that.
I have gotten worried quite a few times working on a radio and not realizing it was on pa or weather.
Fingers crossed. Hopefully you just didn't check the switches.
Posted on Oct 10, 2009
How to wire a superstar DM-452 to a five pin uniden and washington
Trying to wire a dm-452 4 pin mic to a 5 pin uniden ... - Fixya
www.fixya.com/.../t22723929-trying_wire_dm_452_4_pin_mic_5_pin
Jan 6, 2014 - trying to wire a dm-452 4 pin mic to a 5 pin uniden washington -Uniden Bearcat Pro PC68XL ... SOURCE: trying wire a superstar dm-452.
How to wire a superstar DM-452 to a five pin uniden and ...
www.fixya.com/.../t26060852-wire_superstar_dm_452_five_pin_uniden
36 mins ago - how to wire a superstar DM-452 to a five pin uniden and washington - Uniden CB Radios question.
Wire superstar dm 452 mic - Answer
www.dqrkc.com/search/...uniden...pro.../wire_superstar_dm_452_mic
... to a 5 pin how to wire a dm-452 superstar 4 pin mic to a 5 pin uniden washingtonit's not possible to wire 4 wire mics to the uniden 5 wire radios without ...
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio ...
Jan 19, 2016 | Uniden Radio Communications
NO SOUND ON PC68XL UNIDEN CB RADIO
It might be the mic wiring. They like to brake off the back of the plug. If you need repair work. www.herzjoe3@gmail.com
Jun 26, 2012 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I NEED TO KNOW HOW TO ENTER CODES INTO THE SCANNER
hi what do you mean by codes ,or do you mean frequencies ,to enter frequencies press the program key enter the frequency you want to listen too and press enter you can select different banks for different communications ,such as emergency,air traffic,marine,rescue,etc hope this helps
Jan 08, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
4 pin radio (cobra 29) to 5 wire cobrs mic will it work and how Red
hi yes it will work as ive performed this myself a bit of patients needed though hahah follow the below link for the wirering diagrams
uniden mic
Dec 15, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I have a uniden pc68xl cb radio. the radio i can get out but when someone is talking to you it will go blank untill you key up again
Hi, my name is John. Welcome to FixYa. Try turning your SQUELCH all the way to the left, check all your connections, hot (+) wire and your ground (-) wire, also your antenna. Need ant further, let me know. Thanks for choosing FixYa....John
Nov 22, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Best modulation for PC68XL
Most Cobra / Unidens are easy by clipping D9. On this one D9 and L19. Just turn up L19 to top. Clip D9 diode. spread coils 1/16" inch. Also use 100uf capacitor (-) toward final across JUMPER staple near Final Transistor in back. Use meter(adjust to best swing) spread back coils,remove L10,L20 slugs or adjust them to top. The only radio that clips different than D9 is Cobra 29Ltd (D11) or Uniden pro510xl(D14).
Oct 08, 2010 | Uniden PC68XL (40 Channels) 2-Way Radio
Microphone cord pulled out
If you know the model of your radio, this would help.....?
failing that just touch them on pins until it works, belive me if its just a straight chicken box you should be fine.....
May 15, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden pc68xl does not tx or rx. all lights comes on. I have no schematics to work with.
Try to change a 1k resistor R6(I believe) near back of radio. If not, try to change Final. Maybe small transistors near center back to back of radio. If you're not experienced take it to a Radio shop. Sorry i don't have much on this problem.
Jan 05, 2010 | Uniden PC68XL (40 Channels) 2-Way Radio
Running a uniden pc 122 4pin few yrs old wanting wiring colours
Hi
have a quick look at the link bellow that should sort you out
http://www.okdxgroup.co.uk/mic.htm
Regards Alan (alstech)
Apr 27, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden pc68xl
Since this is illegal to do I can't instruct on this matter, but you might do a search on cb sam website. good luck
Ed
NC Electronic
Mills, Wyoming
Nov 08, 2007 | Uniden PC68XL (40 Channels) 2-Way Radio
Radio Communications Logo
54 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
