Question about GE Spectra JBP78 Electric Kitchen Range
When turning on burner (electric) control begins to pop and crack.
    Problem Solver:
  • 5 Answers
You have a wire lose, do not use and unplug the range. Have a tech come and look at the wires.
Posted on Oct 08, 2009
2 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: The burner control goes ''pop.''
Your igniter lead is shorted by some foreign object and needs to be cleaned before it kills the spark module.
This usually happens when you have a pot that boils over spilling liquids and solids on the igniter contacts.
Check the igniter area on the side that doesn't pop to locate the igniter tip, then find the exact match to it on the other side and clean it off with a toothbrush and alcohol.
Posted on Mar 24, 2010
Grill starts then turns off
Need more information because if you have an appliance with some kind of safety valve using an electric sensor or thermocouple there are a few ways to test the problem in order to determine where the actual failure is happening.
With normal residential barbecue grill models I hear this complaint usually with infrared models. If an infrared burner ignites and then blows itself out this indicates the ceramic tiles at the top of the housing are cracked. Over time this will grow worse and can pop or even throw-out flame which can make it scary since infrared burners are so effective because they pressurize the gas for maximum heat.
Oct 19, 2014 | Grilling
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
I have a Char-Broil Tec grill everything works fine but after about 2 minutes into grilling, a loud popping sound and the tec-radiant burner goes out, this happens everytime I use the radiant burners
The radient burner most likely has a crack in the top. This will make the pop and the burner will go out. Inspect the top of the burner for any cracks, if you find one, the only solution is to replace the burner. Since these burners get very hot, I do not recommend having the grill lid closed when these burners are being used, this can cause them to overheat and crack the top surface.
Jul 03, 2011 | Tec RadiantWave Grill
Mar 23, 2010 | Kitchen Ranges
My Whirlpool electric range made a loud electrical popping/cracking noise followed by smoke. Now the indicator light for the left front element is always on. Also when we try to turn on any burner the eft...
Sounds like you have a short in one of your burner switches that may have also taken out your main control. Does your oven work normally? Those error codes are related to 1] control board and 2] oven over temp, so the burner issue is unrelated except in that it may have surged the control.
you can view the switches by removing the rear panel(if this is a freestanding range) and from the description you will likely see the shorted component with some black marks around it. Please unplug the range first,as these wires are live even when all burners are off
Sep 02, 2009 | Kitchen Ranges
When i use one burner the other one makes the electrical pop
That allows you to light that burenr turn the knob to mid range for the gas on both or full on and it should stop. there is one igniter and 4 burners. Each burer controls the igniter when oven calls for gas.
Aug 29, 2009 | Viking Cooktops
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
Cracked glass top
Hello grandmom9 & janlan. I will need the complete model# of your Frigidares to provide the correct part numbers needed. Thank you.
Aug 22, 2008 | Frigidaire FEF366 Electric Kitchen Range
Burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Apr 23, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
