Question about HP Pavilion dv9230us Notebook
Can not get audio out on HDMI on HP dv9230us PC
  • 3,940 Answers
Try making sure you have the most up to date audio driver from HP.COM
Posted on Oct 08, 2009
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
Connected laptop to tv, but sound only come from laptop. How can I make the sound come out from tv?
If your laptop has a HDMI output, and your TV has a HDMI input, then use a HDMI-to-HDMI cable, which carries both "audio" and "video" signals.
Otherwise, you need a cable from the "headphone" output from your PC into the "RCA" stereo-audio inputs into your TV.
Dec 20, 2010 | HP Pavilion dv6-1030us Notebook
I wanted to connect hp dv 4 1275 laptop with sanyo tv with hdmi and 3 rca .but its not working .tried everything din work.
You MUST install HDM IDrivers for your Video Card & MotherBoard. You can only use HDMI, OR Component, but NOT BOTH. Sometimes HDMI, requires an AUDIO OUT Cable, this is the Red & White, AV Stereo input.
OR you use COMPOSITE which is YELLOW, Video, now AUDIO, is Red & White.
COMPONENT, you use, Red, Blue, Green, (ALL VIDEO) PLUS you need the Stereo AV AUDIO too, Red & White.
HDMI, should supply BOTH, but as related sometimes you need the Audio red & White AV, inputs & Outputs.
ALL Cables go color to color.
h10025.www1.hp.com/ewfrf/wc/document?..
Resolving issues,with HDMI. above.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=2100&product=3860476
DRIVERS link above.
Apr 11, 2010 | Computers & Internet
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
I have an HP Pavilion laptop with HDMI. When i
WRONG!!!! do not listen to 002. All you need to do is:
1. right click on volume in lower left
2. click on playback devices
3. choose HDMI
4. click set as default.
Same goes for when you're done watching television, just go back in and set regular computer speakers as default.
Aug 29, 2009 | Computers & Internet
NO SOUND WHEN USING HDMI FROM PC TO HDTV (RUNNING VISTA)
When using an HDMI to DVI cable their is no audio that comes through that cable. Even if you use HDMI to HDMI most computers only have video output from HDMI. You will have to use a seperate audio cable for you to be able to get the sound to work. Depending on the output you have on your laptop you may have to resort to hooking up a pair of speakers to the headphone jack.
Hope this helps.
May 27, 2009 | HP Pavilion dv9030us Notebook
Cannot play in HDmi mode in HP laptop.
Your trying to do something beyond the designed specifications for the inbuilt hdmi module - look at your specs on the Hp website
May 04, 2009 | HP Pavilion dv2000t Notebook
Hdmi audio
The video card should have come with a cable, that plugs into the S/PDIF output on the motherboard. That will let the sound go through the HDMI cable
Apr 19, 2009 | HP Pavilion dv9230us Notebook
HP Pavilion dv9230us Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
