Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Model 55295 - Brushed Nickel Fan with Black Blades
How do I get the light globe off of the bottom of the fan so that I can change the light bulb?
  • 3 more comments
  • Saxman09a Jan 06, 2008
    How do I order a new light globe cover?
  • Anonymous Jan 10, 2008
    How do I get to Light bulb?
  • Sue Olsey Jan 14, 2008
    do not know how to change light bulb
  • cjrguy Sep 06, 2012
    Thanks!
    Thanks!
    Genius:
  • 1,601 Answers
The globe rotates counterclockwise, Apply pressure to the glass,then once it lines up, it slips out. It's a pain and may require some gentle force. If its stuck spray lightly with WD40. Be careful. Saxman, Home Depot would be the only way to get the cover. If they dont have it, you may be stuck.Hampton Bay doesnt sell parts. Sorry.
Posted on Jan 25, 2008
    Thanks!
  • 4 Answers
Like tom19511 said, the actual glass rotates counter-clockwise to get it out. Before I knew that, I nearly pulled the fan out of the ceiling rotating the metal the glass fits into, rotating the glass with someone holding the metal. Then prying at this and that. Mine was so stuck I took the fan off the ceiling. With one person holding the metal that the glass sits in and me with spit on my hands for a better grip, I finally got the glass to budge. What do you know, now it goes in and out easy as pie.
Posted on Sep 17, 2008
Instructions for changing light bulb on Hampton bay model 589 382 ceiling fan.
The answer is already on Fixya :>)
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
How do change the lightg on hampton bay model 589 382
Dec 10, 2017 | Hampton Bay Dryers
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
Want to change bulb on Trident Cosmo; can't get globe off
Try pushing up on the glass as you turn it. Also, I've sprayed WD-40 between glass and fan and that seemed to help.
Feb 01, 2014 | Casablanca Fan Trident COSMOPOLITAN...
I have a double light fan and can't figure out how to replace the light bulb on the bottom
Some globes are held in place by an internal spring clip. If there are no screws around the base of the fixture that can be loosened to remove the globe, this is probably the case. Try to gently, but firmly, remove the globe from the base by pulling down on the globe.
Best regards, --W/D--
Apr 26, 2011 | Monte Carlo (5CMR56OP) Carmel Old World...
I cant figure out how to get at the light bulb to change it
Try pulling the globe straight down. I believe that this model has spring loaded clips holding the globe on the base.
--W/D--
Feb 18, 2011 | Hampton Bay 52 In. Brushed Nickel Romano...
The light is very dim despite changing the light bulb and trying higher wattage light bulbs. All of the other fans in the house have good lighting and no other electrical problems in the room. The blades...
Try holding the remote light button down it has a dimmer built in it should go all the way as bright as it can go then start back down to dim.That is how mine works .
Jan 08, 2011 | Minka -Aire Brushed Nickel Remote Control...
Light fixture on ceiling fan goes off and on
Check the bulbs to see if they are secure but...
Probably after years of use the optional light kit plug has become loose from the vibration. To fix this, turn off the electricity to the unit (circuit breaker is best) take of the bulbs and globes and reove the lighting kit from the bottom of the fan and look for a plug/socket combination and check to see it is secure. There will be many wires and if a remote controlled unit it maybe confusing as to which wires are which yet all should be secure. Retighten the lighting kit, replace the globes and bulbs and turn on the breaker and try again. Good Luck!
Douglas
Dec 26, 2010 | Casablanca Fan Home
How do I change the light bulb on the Harbor Breeze 52" Avian Brushed Nickel? specific directions please
I'm trying to change mine too. I can't figure out how to get the glass off it even.
Nov 29, 2010 | Heating & Cooling
How to chance light bulb
On that model fan the glass globe should unscrew to get to the bulbs if not they are replaced by going between the blades & the motor to the space in between.
Oct 02, 2010 | Westinghouse 78144 Turbo Swirl™ Brushed...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
567 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
