Question about General Electric DBSR463EGWW Dryer
How do you change a light bulb in a GE Profile electric dryer?
    President:
  • 1,304 Answers
The light should be dead center wqhen yuo open the door
a small philips screw
pop off the lens
yse a xmas light
you will see when you take off the lens
Posted on Oct 08, 2009
revamos
  • 16 Answers
SOURCE: GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Posted on Apr 20, 2008
dragonsthatk
  • 547 Answers
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
  • 33 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer not heating up
Check the air flow from the vent-if there is no air or very weak air flow, it is the blower motor. It is not getting up to speed or not spinning at all. Try this:
Press "Home"
Press "Help"
Simultaneously press and hold down BOTH
"My Cycles" and "Back"
After a few seconds the dryer will enter service mode and report any problems.
Pertains to GE Profile HarmonyDPGT750EC/GC
Posted on Aug 07, 2009
ftw1952
  • 10319 Answers
SOURCE: GE profile harmony dryer has power, drum turns,
check out the ignition spark ignitor
that makes the burner to heat up
Posted on Mar 12, 2010
ginko
  • 19396 Answers
SOURCE: Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Posted on Jul 11, 2010
Can I run my GE dryer without a light bulb in?
If there is something covering the socket yes, An exposed socket would not be a good idea.
Jan 29, 2013 | GE Profile Wizard DPSE592EAWW Electric...
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
Aug 11, 2009 | Whirlpool GEW9200L Electric Dryer
GE dryer does not run and just hums
Yes, open it. You'll probably find a broken or loose belt.
More help?, let me know.
May 09, 2009 | GE Profile DPSB619ED Electric Dryer
GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Light bulb is out
The bulb is on the inside of the door face frame, just above the door.
Feb 17, 2009 | GE Profile DPSB619ED Electric Dryer
Can dryer be converted
ummm, hter is NO way to convert a gas dryer to electric, you can have a gas dryer converted from naturall gas to lp gas, but not to electric, two totally different machines.
Nov 23, 2008 | GE Profile DPSB620GCWW Gas Dryer
GE Profile Performance Dryer
GE Easy care 4 prong Installation
Grn = Ground
White = Neutral ?
Black = ____ top or bottom?
Red = ____ top or bottom?
Please advise
Aug 19, 2008 | GE Profile Harmony DPGT750EC Electric...
General Electric DBSR463EGWW Dryer Logo
158 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
