Question about Miller Electric Mfg Co 903505 Invision 456P MIG Welder , 3- Phase, 10 - 38 V Type: 230/460 60HZ
I have a miller welder powered by a tecumseh engine. this welder has a systen that advances the throttle when an arc is struck. Is this system part of the engine or an attachment from the welder?
    Scholar:
  • 173 Answers
The low idle works off a pc board and idle solinoid. The high idle is controled by a governor
Posted on Oct 03, 2012
    President:
  • 3,433 Answers
Part of the engine, load sensing
Posted on Nov 12, 2009
What size motor came out on the miller blue star 2e welder
Depending on serial number, Miller started out with Kohler manual start, Kohler electric start, and then Tecumseh electric start. They ended the series with a Tecumseh OH160, miller part #070732. I have included the manual. https://www.millerwelds.com/files/owners-manuals/O424E_MIL.pdf
Sep 11, 2017 | Miller Welding Tools
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Miller 130 wire advances, fan runs, but will not arc as wire comes out
Most of these machines (would have to have serial number to be sure) will not feed if their is no output voltage, since part of the motor voltage comes from the arc voltage.
So, I would suspect broken wires, either in the work lead or the gun. If it arcs just a little, probably the gun. One place the work lead breaks is right at the back of the clamp. Pull on the insulation and see if it "stretches". If so, the wire there is broken.
Feb 21, 2015 | Miller Welding Tools
Trouble shooting miller trailblazer 302 engine powers out when air arcing
Blow cabinet clean of dust and check connections in cabinet and handle. first, Then check the wires to the step up solenoid and make sure they have sound connections and that solenoid is mounted securely. If you do much outside at night, have someone watch with the cabinet open and see where it sparks when the engine drops speed. Int he dark, even small sparks you would not see inthe daytime or the shop apper reasonably well.
Sep 24, 2012 | Miller Trailblazer 302 Welder Generator...
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
The tig welder will arc but there is no amperage and nothing is heated up it acts l;ike there is no amperage?
Make sure you have a good ground. With high frequency you can get it to still arc but have a bad ground.
Jun 11, 2010 | Miller Hf 251D 042388 Tig Hi Freq For...
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Miller Electric Mfg Co 903505 Invision 456P MIG Welder , 3- Phase, 10 - 38 V Type: 230/460 60HZ Logo
587 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
