Question about Marantz Audio Players & Recorders
Marantz SR870 tuner not working
I have a Marantz SR870 unit that everything works on except the radio tuner - FM hisses like the aerial is disconnected and AM is completely silent. No obvious signs of broken wires or bad soldering in the aerial connections. Any ideas? If all else fails, is it easy to connect a separate tuner?
  • 30 Answers
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Posted on Oct 09, 2009
Everything OK, except no sound from the FM tuner.
You may have many different issues in the FM circuitry. Do any other FM stations come in?
If you are interested in having your Marantz repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 21, 2015 | Marantz SR6006 Home theater receiver...
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
The stereo light on my marantz 2226b receiver does not come on even on a stereo fm station
my first question is does the light come on when you turn to Tape, Phono, Aux selection? If no lamp is blown, if it does come on then your tuner need to be serviced. FM tuner work is NOT for a novice. I would be glad to take a look at the unit.
Thanks
www.back2lifeelectronics.com
Sep 23, 2012 | Marantz Audio Players & Recorders
Is the aerial input on a Sherwood Stereo tuner TD130SB 75 or 300 Ohm?
You can use some speaker wire. and pull it apart until each leg is 2 1/2' long and then connect it to the balanced antenna input. Or you can run that 2 1/2' (each leg) of wire to the the coax connecting one side to the shield and one side to the center core of a 75 Ohm coax and then run the coax to the FM input on your reciever. The (two) [2 1/2'] legs create a dipole and the coax prevents high SWR and improves recieve. Remember it will work best the higher you get it.
Regards,Tony
Apr 12, 2011 | Marantz ST7001 AM/FM/XM Stereo Tuner
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
Put the radio in my truck about 4 months ago, worked great. the truck sat for months because it was broke, now i get it fixed, put the face on my radio and everything is on, my radio, my amp is running but...
Turn the volume up to the highest level.
Can you hear a hiss or static?
NO...usually means speakers are disconnected..often loose socket at rear of radio or broken wiring
YES...Hiss means either blown speaker, faulty radio or faulty aerial.
If you have tape or CD as well , this will prove whether it is the aerial or not.
HISS with CD or tape playing means faulty radio or speakers
WORKING OK with CD or tape means faulty aerial
Feb 20, 2011 | Car Audio & Video
I'm trying to connect my cablevision coax to my Pioneer VSX-1019 reveiver so I can listen to FM radio through the tuner. The antenna connection on the receiver is a female European PAL (also called as...
Is this what you need? http://cgi.ebay.com/4pc-Gold-Plated-Aerial-Female-Aerial-Female-Adapter-/180435080974?pt=LH_DefaultDomain_0&hash=item2a02c4d70e
although I would be surprised if the signal you have would be correct to supply your fm tuner, you may be better off with something like this (depends on how good your fm signal is locally) http://cgi.ebay.com/FM-AERIAL-KIT-RADIO-RECEIVERS-BALUN-UNIVERSAL-/310283558296?pt=LH_DefaultDomain_3&hash=item483e575d98#ht_2068wt_876
Alternatively, and I know this sounds crude, poke a long piece of wire into the centre of the aerial socket on your tuner and pin it to the wall or a door frame, it often works if you have a decent signal to begin with.
Jan 11, 2011 | Pioneer VSX-1019AHK A/V receiver
In my philips SAA1732 fm is not working, if put scan, it scanning my no channel were is found. i connect to outside aerial but it still not detecting any fm stations... what i should do sir, please suggest...
You probably need to install a proper fm aerial and diplexer, is your aerial a TV aerial or a radio aerial?
You need to set it for the correct TV system in the software to get the audio from the TV, there will be a number of options like PAL I or PAL M or N. etc They have different sound settings, you need to choose the correct one for your system.
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Dec 03, 2007 | Marantz SR-6200 Receiver
229 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
