Question about LG Heating & Cooling
LG A/C SPLIT UNIT, DURING DAYS WE WERE SMELLING GAS THEN SUDDENDLY ITS NOT COOLING ANYMORE, SO WE THINK THERES A LEAK, HOW TO FIND IT AND FIX IT?
  • 25 Answers
You will need a pair of guages and some nitrogen. put pressure to the lines and listen for the "hiss".rubbing soapy water on the area where you think the leak is at will make bubbles (the leak). another way is dye but i do not reccomend it. once you find the leak you run into the problem of soldering the leak and recharging the system, which requires an epa license for the purchase of refrigerant. yout best best is to call the pro's. this is tedious work.
Posted on Oct 09, 2009
Testimonial: "THX VERY MUCH BROTHER,I GOT IT"
LS-1260HL split A/C. Why isn't it blowing at full speed in cool mode?
ice on indoor units can be from blocked evaporator fins / blocked filters
inspect the fins under the filter pads and if they look greasy and dirty have the indoor unit professionally cleaned as it is messy
Jan 23, 2016 | LG Heating & Cooling
Cannot find a filter location for RCBA 4882GG21.
it is either in the bottom of the indoor unit itself, in the door below the inside unit (if equipped), or in the grill on the wall or ceiling
Sep 30, 2012 | Ruud Matching Split Air Conditioner
I had bought a Lg inverter wall mounted unit it worked about 3 days but it didnt cooled the area and i decieded to changed the outdoor unit(compressor)according to repairman's advice .during the first...
You changed the compressor?? Why ??? These models do not normally have problems with this. I am conversant with most of the LS series and these have capacitor start compressors, which fail all the time. Generally all models have either a 45 /6 uf or a 50 /6 uf capacitor. If this fails, the compressor wont start, thus a no heat, no cool problem. If you have changed the compressor and made sure it is actually running, what is the operating pressure?? Suction side should be around 0 to -5 degrees c. Perhaps there isnt any gas in the system??
I assume by doing such a repair you are licensed to do so and have all the proper equipment to recharge the system ???
Jun 16, 2011 | LG LSC121PMA Split System Air Conditioner
When do i refil gas is it when is on or off
why do you think you need to refill the gas ? what kind of gas are you putting in it do you know how to tell how much you put in. the gas never runs out if it is not cooling as good and you think putting more gas in it will fix it think again. it might have a gas leak and if it does its highly illegal to add more gas to it.. you add gas when its turned onto cooling on the big pipe side but please rethink what your doing and answer some of my questions first.
Nov 11, 2010 | LG LS-K1830HL Heat Cool Mini Split Air...
LG la125hv mini split not cooling; one of theoutside lines have thin ice on it. Small leaking from the inside unit. Water and oily substance as well
You have arefrigerant leak and the unit is low on charge....you will need to have the leak fixed and the unit recharged by a professional...
heatman101
Aug 28, 2010 | LG Heating & Cooling
Gas smell inside maytag neptune gas dryer
gas has an oderant added to it and in your dryer in the cool down it allows most of the gas to be removed.if you smell gas when the dryer is off and empty, then you have a gas leak.thanks karl
Jan 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I HAVE AN AMERICAN STANDARD HEAT PUMP/AIR CONDITIONER UNIT OUTSIDE MY MOBILE HOME A FEW DAYS AGO A UNKNOWN SMELL COMES THRU ALL VENTS IN AIR CONDITIONER MODE ONLY. WHEN HEAT IS ON THERE IS NO SMELL UNTIL...
This is a condition called Dirty Socks Syndrome air cleaners and dehumidify usually fix the problem also adding a uv light to the duct can remedy the problem the light is probally the cheapest solution
Dec 04, 2008 | LG LS-K1830CL Cool Mini Split Air...
Heating & Cooling Logo
95 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
