Question about Motorola Talkabout T5500 Rechargeable 2-Way Radio
MY UNITS WILL PICK UP SIGNAL BUT NOT PICK UP EACH OTHER. THEY ARE ON THE SAME CHANNAL AND SAME CODE. WHY?
  • Motorola Master
  • 1,654 Answers
Check your Qt filter. Set it to the off position (the minus symbol) on both radios. Once you have your Frequency, Interference Code Eliminator and Qt Filter set identical, the radios should communicate. If not, you have a radio with a problem. Or a bad battery. (Bad batteries can also cause some user problems, such as no transmit or intermittent transmit.)
Here is a link to the user's guide, the Qt filter is on page 21: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Another test of the radios would be to put both Codes to zero and see if you can communicate without the code turned on.
Posted on Oct 08, 2009
Why can i not get channal 44 to tap on vcr
When the VCR was set up did it pick up a signal from a weak transmitter that can pick up all the other stations good, but can't that one? If so retune the VCR and makes certain that only the strongest station is picked up.
Aug 12, 2014 | Toshiba Televison & Video
94 toyto pickup 4cyl. no signal to inj.
Hi Dan, I believe that on that model of vehicle a distributor was used. The signal for the injection is generated inside the distributor by a second rotor and pick up coil below that for the spark. Check the cables carefully and then the pickup coils. If all else fails, try a replacement ECU. Good used units should be available at a reasonable cost. Regards John
Sep 16, 2012 | Cars & Trucks
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
Feb 14, 2011 | Midland Two Way Radio
The modal is a 37inch samsunge modal le37a557p2f and it just keeps cummin up no signal on the screen wount giv me any channal at all and im pluged rite in 2 the ariel at the mains and i no my arial is good...
Go into the menu and make sure that it is set up for the type of signal you can receive. Some will receive terrestial and some are set to receive digital. If it is set up wrong, it will give the no signal message because there is either no digital available or no terrestial avalable.
Oct 16, 2010 | Televison & Video
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Dec 09, 2009 | RCA Universal Remote Control
Coby tf-tv700 a 7in lcd tv will not git channals since diggital s
Go to menu pick rescan channels,not getting more channels,get digital antena.Rescan again.
Aug 15, 2009 | Coby TF-TV700 7 in. Portable Television
Just bought a new Tascam 2488 portastudio. Following directions to record first song, but I can't get sound through either headphones or monitor outputs. I know I have a signal because I can overdrive it...
Read page 19 under Monitor section.You have to assign the signal to the monitor output you want. Page 36 has the details. All the info you need is here with some updates:http://www.korg.com/product.aspx?pd=191
Jul 26, 2009 | Tascam 2488mkii 24 Track Recording...
Trying to use multiple base units
It is not possible to set up 2 base units to work with same handset as the base unit and the handset are tagged by their operating frequency, which also works as the privacy filter for the user, so that your neighbors cannot pick up your line and use on your expense. For your requirement you need a DECT system that can support multiple base stations.
Feb 15, 2009 | Panasonic Lands Phones
Sanyo DP 37647
What input did you connect the satalite to? Probably one of the 'video' inputs I'm guessing, which means you have to select that video source using the 'INPUT' button on your remote. (Some makers use different names but you get the idea)
Hope Ya Fix it!
Dec 29, 2007 | Sanyo DS27510 27" TV
Motorola Talkabout T5500 Rechargeable 2-Way Radio Logo
90 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
