Question about EA Sports Video Game Consoles & Games
Problems with my disk - EA Sports Video Game Consoles & Games
  • Paul May 11, 2010
    What is wrong with your disc? Please explain it, and I'll do my best to help you.
    Problem Solver:
  • 5 Answers
It could be a lot of problems dvd drive could be bad, the disk could be bad. You have to explain a little more about what is wrong.
Posted on Dec 09, 2009
Flashing question mark on macbook
The problem is the MacBook is unable to find the "designated" boot device. The problem can caused by several things. The most likely is also the worst possible cause. The most likely problem is that the hard disk is not working correctly. To diagnose the problem follow the following steps:
  • If you have your original disks, boot the install disk
  1. Restart the computer
  2. Insert boot disk in the optical drive as soon as you turn on the computer
  3. Hold down the 'c' key on the keyboard to signal the MacBook to use the optical disk to boot the computer.
  4. Once the computer is booted, use the Disk Utility from the Utilities menu to examine and if necessary repair the hard disk.
  1. Start by ensuring that your internal hard disk is listed.
      • If your disk is not listed, then your hard disk is definitely having a problem. If you are lucky, it maybe just that one of the cables has become disconnected. I believe on your MacBook, the hard drive is accessible by removing the battery and the hard disk is located next to the battery. You would need to post your model number to get exact instructions.
  2. If so, then run the Verify Permissions and Verify Disk. Run repair if there are any errors detected.
  1. Once you have checked and repaired the hard disk, exit Disk Utility and run Startup Disk from the Utility menu.
  2. Select your Hard Disk and click Restart
If you are lucky, the computer will run again. If not, check your install discs. The original install discs usually have a hardware diagnostic which can be run by holding down the 'd' key while booting. You can try running the diagnostics to see if you can diagnose the cause of the booting problem. You can also use the diagnostics if your hard disk is not shown in the Disk Utility to run diagnostics on the hard disk.
Post the results of your testing so I can help further or know that you have found a solution even if it is to get a new hard drive and restore your system.
Thanks, Jim
Aug 14, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Makes squeeling sound when disk is inserted
this kind of problem normally occurs in nitendo wii......make sure that the disk u using is original disks.. by using pirated disks create such problem...clean ur lens before insert disks..
otherwise using repair guide u easily solve this problem..all the best
Dec 06, 2010 | Nintendo Wii Console
My octave copy master has a hard disk problem. if i reformat, do i need a disk to format?
Ok, first, "reformat" means you have done a format before, **** your question (about the format disk), explains that you havint?
..so have you?
OK, second, if you have a hard disk problem, you must to know what is the problem first, to solve it. (the solution might be a lot easier than it appears)
THE problem might be, a phisical problem , where your here sound comming from the disk, or a hardware/software problem, were your disk Master Boot Record (MBR) is damaged , this can cause booting problems, and even alot more.
SO u need to locate the problem, when doing this, you will find a lot of solutions, and alternatives for solving your problem....
CHECK if your hard disk is beeing recognised at startup, or in bios.
if it is, then problem one, can be bypassed, and you can continue to the next problem were you have alot of solutions.
Well this is not a solution for your problem since the discription is not enough to identify it, **** i think this can give an idea and a basic knowleg on whats MIGHT be going on.
and Finally, yes you do need a format tool, the simplest way is to insert the setup disk of any operating system (beside linux if your not familiar with it), and format it, i recomend the windows xp setup disk its the easier!
gd luck and lett me know what have you done.
Jan 01, 2010 | Octave Copy Master II Burner
Disk in h is not formatted
As I understand, you inserted a disk in a card reader and you were connecting the card reader into your computer, is it right? If yes, then the problem could be the disk or the card reader.
* First, try connecting the card reader into different USB port.
* Try connecting it in a different computer just to isolate the problem.
* If the problem is isolated to the disk and card reader, try inserting another disk just to make sure that the card reader is working and plug it in to the computer.
* If another disk works with the problem card reader, then buy a new disk. But if same problem occurs though you use another disk, try another card reader.
Doing these steps would let you know which is causing the problem.
Have a great day!
Oct 18, 2009 | Rio Tablets & eReaders
Dvd not taking any disks
I did not get my problem solve do you have a remedy to solve my problem
Aug 15, 2009 | Samsung DVD-R130 DVD Recorder
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Dvd drive
i think the problem is with your current disk you were trying to play. clean the surface of the disk and try again. if it continue to cause problem then don't use that disk, it is a fault disk
Jun 25, 2008 | Toshiba Satellite A135-S4527 Notebook
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Video Game Consoles & Games Logo
32 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
Deepak Koshy
Deepak Koshy
Level 1 Expert
param99
Level 1 Expert
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
