posted by Seminole on Dec 24, 2007
Dear Guru:
After I set the heating thermostat set point ("ST" on the unit) (say 75 degrees), my heater will run if the room temp ("RT" on the unit) is lower than 75 degrees. However, after the heater runs and reaches 75 degrees, the "RT" will stay at a temp higher than 75, sometimes in the 80 to 83 range. In turn, the heater will not come back on because it thinks the room temp is higher than 75. I know the room temp is not higher than 75 because I have a separate thermometer in the room to measure the room temp.
Thank you.
Solution #1
posted on Dec 29, 2007
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for EdgeStar 12,000 BTU Portable Air
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
EdgeStar 12,000 BTU Portable Air Conditioner...
EdgeStar 400S portable AC
Does not seem to cool as well... Answer This...
portable air conditioner 10000
I am looking for a dependable... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
