Home | Sony | KDS-50A2000 50 in. HDTV Television | Sony KDS50A2000 pow...
Sony KDS-50A2000 50 in. HDTV Television
Problem for Sony KDS-50A2000 50 in. HDTV Television
Sony KDS50A2000 power LED flashes green, then
By IMCAmodRacer on Oct 08, 2009
Sony KDS50A2000 power LED flashes green, then clicks off and flashes red four times over and over.
Comments:
Oct 08, 2009
- Thanks very much, you just saved me money that I don't have. You have no idea how much your help with this means to me!
Best Solution
posted on Oct 08, 2009
Very Helpful)
zapdbf
Rank: Guru  Sony Expert
Rating: 96%, 85 votes
4 blink is a fan error. This is caused by one of the three fans not spinning fast enough or has stopped completely. The fan that usually causes this error is the one over the bulb and toward the back of the set. The repair is not expensive, but to do the service correctly you must get all the dust out of the tv or the fan will clog up very fast again. Getting the dust out is kida tricky because you have to get the dust out without contaminating the light engine, if it gets contaminated you will get colored splotches on your picture. I recommend getting a pro to fix it, the repair should be fairly reasonable around $150 to do the repair. The fans are not that expensive.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony KDS-50A2000 50 in. HDTV
Questions and Unsolved Problems for Sony KDS-50A2000 50 in. HDTV
Do you recommend Sony KDS-50A2000 50 in. HDTV Television?
Answer
Answer
pictur is green 70% .bulb is new.black -wite pictur goes to green
Answer
Power Light continuously blinks with no picture or sound. The Ballast and S2 Board have been... (More)
Answer
picture is on the green side and I tried to adjust it in the menu but no help
Answer
I tried a new lamp. That did nothing. I tried all kind of different settings and that did nothing.... (More)
Answer
I just put in a new lamp,but didn't seem to help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KDS-50A2000 50 in. HDTV...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
