Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Think carberator is clogged up dont know how to clean
Think carberator is clogged up dont know how to take apart.
  • 4 Answers
Now days some of these carbs prices are reasonable enough to just replace it and be done with it. i would get my model, type, and code #s or whatever is on the motor, then call and price the carb
Posted on Oct 09, 2009
Will not start without priming the carburator, and then only run for a few seconds
It's not getting fuel thru the carberator another solution is the needle is stuck sometimes after it sets over the winter the needle ( which has a rubber end ) sticks closed
Apr 29, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
My truck stalled yesterday a.m. - someone added gas to the carberator and it started right up. Today it won't start at all. I'm thinking it's a fuel injector problem.
It might be but first, is your fuel pump kicking on? Also, a clogged fuel filter can cause this as well. Listen for your fuel pump to kick on. If it doesn't, it might be your pump. We know it is gas related and that is good.
Feb 05, 2011 | 2000 Chevrolet S-10
My chevy blazer is turning over but it won't start even when I put gas in the carberator.
You don't have a carberator on it, it's fuel injected. Id try spraying carb cleaner in the throttle while you have someone turn it over. If it fires up for a few seconds then dies then you might have a fuel pump problem or fuel filter clogged. If it still doesnt fire up then check if you have spark, if no spark see if your crank sensor is good and if your coil is getting power. If your coil is not getting power you might have a crank sensor problem. Try this and let me know if it helps.
Feb 03, 2011 | 1996 Chevrolet Blazer
My car sometimes seems like it dont want to get fuel to the carberator,i put cleaner in it sometimes, does the carberator or fuel injection need to be changed.
cant answer it unless car is in front of me could be a fuel pump issue could be a cloged fuel filter what makes you think your cars not getting fuel
Nov 29, 2010 | 1988 Oldsmobile Delta 88
Hi there,i have a mcculloch tm210 petrol strimmer and the problem is that it will not start,i have noticed that the fuel primer bubble dose not come back out.please can you advise.
clogged fuel line or carberator. my weedeater did this at the first of the season. i took off both lines going to the gas tank and blew on each line separately while holding throttle open on carberator. i felt the clog go thru and put back together, poured a little gas in intake and it started right up and the primer worked right. good luck
Jul 03, 2010 | Garden
Putting the carberator back together.
one end to the govenor other end to the throttle on carb
Jun 30, 2009 | Craftsman Garden
110cc pocket bike carberator
That tube would be the overflow tube. Your carb float is sticking open and allowing fuel to flow in constantly. You need to take carb apart, clean needle valve, and inspect or replace carb float.
Apr 21, 2009 | Pit SSR 110CC Pro Beginner Bike
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
