Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Need to remove agitator to remove lodged medallion
Son's Scout medallion broke and slide under agitator of Cabrio washer. how do I get agitator off??
    Brigadier General:
  • 4,088 Answers
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Posted on Oct 08, 2009
Testimonial: "Thank you so much. I had figured out how to unscrew agitator, but was affraid to pull 2 hard as I thought I might break it. Your 2 step method works"
Code f51
If its under the agitator, simply unscrew the top of the agitator, pull up the agitator and remove the Necklave. If its under the tub itself, you need to access it from underneath, which means you will need to take off the entire outside cover, starting with the top. Once you have removed the entire cover, then you will need to remove each piece that is blocking you from getting to the Necklave. This process is better done by an appliance repair person.
Jul 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Change got under agitator how to get out
the top part of the agitator should simply pull off and down the bottom of the agitator in the middle there will be either a large wing screw you can undo by hand or there will be a small (10mm i think depends on model) screw u need to undo then u just pull the agitator out (may be very tight if its never been removed)
May 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
    Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
    Manual and parts list click here.
    Hope this helps.
    Zeppelinx12
    Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My sleve is stuck in the spinning deal of my washer, how do i get it out?
    Remove the rinse dispenser from the top of the agitator (spinning deal). Unscrew the agitator cap located on top of the agitator which is only hand tightened. Once the plastic agitator cap is removed from the top of the agitator you should see a screw which you will need a socket or an adjustable wrench to remove the screw. The agitator can now be removed by lifting strait up to free the sleeve. My only concern is how the sleeve became lodged under the agitator unless the tub became unbalanced from a heavy load. The other possibility could be the support for the tub is broken and needs to be replaced.
    Feb 15, 2011 | Admiral AW22 Top Load Washer
    My problem is the agiator tears my clothes what is wrong this does not happen everytime just sometime and ravels towels?
    Perhaps you need to remove the agitator and look under it for objects that do not belong.
    In the past I have found items of clothing and such.
    Cabrio service manual
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer is blinking F 50. what do I do?
    Motor has stalled, check under basket, for something around shaft,you will need to pull out basket ,pop the cap off the agitator, remove bolt ,unsnap tub ring remove return hose ,pull the basket out, clean area area shaft
    Jan 27, 2011 | Whirlpool WTW6400SW Cabrio Washer
    Material chord lodged around agitator of kleenmaid KAW393 washer
    sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
    Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Want to remove the agitator to look for my lost diamond ring
    If your ring was small enough to go through the holes in agitator, then there is a pump under the washer that has plastic and rubber parts that can be removed. Especially Kenmore which should have a rubber boot type looking thing under the pump. You can't miss it.
    Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    1,638 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
