Question about Logitech Pure-Fi Express Plus Omnidirectional Speaker Dock Remote Control for iPod and iPhone
Remote control buttons won't work
Some of the remote control buttons won't work. The volume buttons work fine, but if I want to skip to another song, that button doesn't work. If I want to pause, that button doesn't work either. I changed the battery so that's not the problem.
    Problem Solver:
  • 14 Answers
You may have a fualty remote you may want to bring it back theres nothing you can really do
Posted on Oct 08, 2009
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
RAV311 WJ40930 VOLUME CONTROL
Might be the fault to remote control, to respective buttons contacts [inside] it. You have to clean the remote control to make it work. If you wish to get more details about how to check, repair and clean a remote control, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 04, 2013 | Televison & Video
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
My remote doesn't work. I put in a new battery; still doesn't work. Bought a new one from Bose.com, new one doesn't work. Am I doing something wrong? Do I need to reprogram or reset the Sounddock?
Had the same problem. I resolved it by removing my iPod from the dock and unplugging the SoundDock. I waited a few seconds and plugged the SoundDock back in. I then placed my iPod back into the dock.
I played a song and tried to use the right/skip button to skip to the next song. At first it didn't work. Then, I held the right button down for a few seconds. After that, all buttons worked just fine.
I hope this works for you. In case it doesn't, here is what the user manual says:
• Remove your iPod from the dock, wait five seconds, then firmly reseat the iPod in the dock.
• Try the remote from a different location. If it works there, check for interference from bright room lights or sunlight. Wipe off the small lens on the front end of the remote with a clean, dry cloth.
• Make sure there is a clear pathway between the remote lens and your SoundDock system.
• Remove and reinsert the battery as shown on page 6.
• Replace the remote control battery as shown on page 6.
Apr 22, 2010 | Bose SoundDock® (Black) Docking Station...
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Remote will not change the volume
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Time Warner Remote Code to work volume for Philips Home Theater
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
Dec 23, 2008 | Audio Players & Recorders
Logitech Pure-Fi Express Plus Omnidirectional Speaker Dock Remote Control for iPod and iPhone  Logo
635 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
