I have an MFC8460N and it grinds when I put the paper tray in Is it the Drum?
    Guru:
  • 389 Answers
Check the remainder of the paper in pallet. Check the condition of the rubber roller and brake platform under roller, presence of the slanting of the spring.
Posted on Oct 08, 2009
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
We have a MFC8460N, when we go to make copies there is a loud clicking noise & it says 'paper jam' & will not make copies
Hi
The clicking sound comes from the paper tray. The problem is that the paper gets jammed when it feeds the paper and it will sound clicking because the printer cannot pick up the paper at the tray.
What you will do is to put bond paper into a tray but the paper head should not be so tighten. Just put the bond paper with the top paper in upward position.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 02, 2011 | Brother MFC-8460N All-In-One Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Dec 21, 2010 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
I have a paper jam in Tray 1 where is Tray 1
Hi Yor tray 1 is the first tray where you put your A4 paper in have look to see if the paper not to tight and maybe you can take your tray right out then look at where the rollers take the paper up it may be in there.
I have put a PDF files on my website for you to download.
Brother-DCP-9040CN-DCP-9045CDN-MFC-9440-MFC-9840.PDF
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and save it to your PC.
Click LINK= http://www.4all2sell.com/pdf/Brother-DCP-9040CN-DCP-9045CDN-MFC-9440-MFC-9840.PDF
You need a adobe reader to see this file If you not got a pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 08, 2010 | Brother MFC-9840CDW Laser Printer
Grinding noise, no paper feeding from tray
This will work.
If you remove the paper tray you'll notice a black arm hanging down in the middle of the printer...this should be up inside (the cause is too much paper being put in the tray then when the user tries to remove the tray it hooks this and causes it to be in the way of the paper when it rises).
Disconnect the power and remove the toner/drum. Turn the printer upside down and remove the rollers from the purple plastic arm (shove the arm ahead to make this easier). Once you have this disconnected and removed you'll be able to see where the black plastic arm should go. You can push it back up in the printer without too much fuss. Replace the rollers where they go and put everything back together. Voila!
This has happened twice in the past year and both times this has fixed the issue right away. Good luck! :)
Jun 05, 2009 | Brother HL 5250DN Laser Printer
Paper curls on 8460 Brother
The following is Brother's take on your problem. All of their solutions have some merit but the one I'm leaning toward is overstuffing of the paper tray. It's common in most offices (and homes for that matter) to have a tendency to stuff the paper tray when it runs out.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000000618&Sympt=The+faxes+I+receive%2c+copies+I+make%2c+and%2for+documents+I+print+from+my++computer+have+a+curl+or+wave+to+them+when+they+feed+out+of+the+Brother++machine.+What+can+I+do%3f+(paper+curl)&Model=270&ProductGroup=5&Keyword=paper%20curls&ProductID=MFC8460N
Apr 23, 2009 | Office Equipment & Supplies
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother mfc8460n message no tray. tray is in.
The sensor also has a spring to the left that enables it to go to its default location. If this spring is missing then the sensor will not detect the tray and display the "No Tray" message even though the tray is in place.
Jan 15, 2009 | Brother MFC-8460N All-In-One Printer
15 people viewed this question
jasbo
jasbo
