Question about Jenn-Air JCD2389G Side by Side Refrigerator
A fishy smell coming from fridge
A fishy smell coming fom fridge. The filter says it need to be replaced, not sure how to get that out.
    President:
  • 1,304 Answers
If its onb the back wall in the upper right corner 1/2 turn then pull down
if in the toe kick
1/2 turn then pull straight out
then push lock and light for 5 secs to clear change lite
Posted on Oct 08, 2009
My fridge smells fishy. It is perfectly clean and i have not had fish in there.
Bacteria will cause the smell. Make sure it is cold and put a box of baking soda open inside the fridge. It will absorb the odors. They sell baking soda with a mesh side specifically for your fridge.
Jun 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Getting a funny, fishy smell from my dryer. Whirlpool Inglis.
Check the power cord. The fishy smell is probably from the power cord that is scorched. If so, detach the power cord and bring it to a hardware store to find a replacement. Home Depot or Lowes should have it for about $13. If you are not sure how to detach and re-attach, google how to do it and you should find videos. BTW: While you have your dryer out, clean the filters with a dryer brush. You can get this at Lowes.
Nov 29, 2010 | Whirlpool Inglis IP8200 Dryer
Fishy odor
Make sure you wash the refrigerator and freezer with a baking soda and water solution.
Then, place a few charcoal briquets in the fridge and freezer areas.
The charcoal will absorb odors. It works wonders.
In one month, you can remove the briquets and scrape the outer layer off to renew the usefulness of the charcoal.
Oct 09, 2009 | Refrigerators
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
Apr 01, 2009 | Refrigerators
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Smell in my caravn
it may be a coolant leak in your heater core, but coolant has more of a sweet smell than a fishy one, and you would notice a dampness on the passenger side floormat. it is probably just a mold in the air filter of the blower motor and needs replaced
Nov 30, 2008 | 2004 Dodge Grand Caravan
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Feb 04, 2008 | Maytag MBB1956GES Bottom Freezer...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
253 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
