Question about Coleman Air Tools & Compressors
What settings do I use for the VP201 compressor
What settings do I use for the Coleman VP201 powermate air compressor 75-100 psi and what about the other gauge?
    Sergeant:
    Champion:
  • 269 Answers
Leave the compressor setting to the highest level.The other guage is to regulate the pressure output.For example if you need 40 PSI turn this regulator until this output is reached
Posted on Oct 08, 2009
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need User Manual for Coleman Powermate VP201
Scroll down to model VP0000201
Should be what you're looking for, manual is in .pdf format available for download.
Feb 11, 2011 | Vacuums
Compressor pressure only to 60 lb psi and no more
not sure but it sounds like the piston ring is worn out or you might have a bad valve.
p.s. its not your typical valve like in a car.
is it a wet compressor, check the oil.
Feb 21, 2010 | Coleman Powermate 27 Gallon Air Compressor
Manual for coleman vp201 air compressor
THE PSI RATING IS 70-100PSI. I WASN'T ABLE TO FIND THE SCFM AT THEIR WEBSITE. NO MANUALS AVAILABLE AS OF YET.
Jan 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
The pressure reads 40 psi on both guages on this
with it running check regulator knob .it pulls up turn right pressure should go up.if not regulator bad
Jun 20, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Coleman 11 gallon air compressor wont start
Sometimes the initial start up with the tank at 0 psi electric power is adequate. However when the tank is full or the garage is cold it is a bigger load for start up. Check your overload (reset button) and breaker. If 220 volts one side of the breaker could be tripped without showing.
Feb 14, 2009 | Coleman Powermate 11 Gallon Air Compressor
Air Tools & Compressors Logo
274 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
