Question about Air Tools & Compressors
Compressor keps running but the pressure does not go above 40psi
  • 87 Answers
You need to change your regulator, and or turn your current one up. hope this helps
Posted on Oct 08, 2009
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
No fuel pressure unless running. 40psi when running. can't get rpms up enough to drive
pump on its way out tats wit happend to me new disel pump sorted tat
Jan 25, 2013 | Cars & Trucks
I have a model# 919166442 air compressor that all at once quit building air pressure. when it gets to 40psi the engine keeps running but air pressure wont rise
There is a check valve that has gone bad,this allows air into the tank,and does not allow the air to go back toward the compressors head.This can also cause the compressor to lock up.
May 17, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
There is a black tube coming out of the check Where does it go?
This line should go to the unloader valve on the pressure switch, and is used to vent the head pressure when the compressor shuts off. When attached to the pressure switch, it will be sealed off until the compressor pumps up and shuts off, then it will bleed off briefly so that the motor starts easier the next time it starts.
Oct 28, 2009 | Campbell Hausfeld 5.0 Hp Cast Iron Air...
Air Compressor stalls when it reaches @ 40psi. Have a
You need to find an amp probe from someone and use it to monitor the amps as the compressor is building up pressure. If the amps start increasing dramatically as it nears the stall point it would seem that you have a seizing problem or electrical motor problem. This answer only applies to the exact statement that you gave. ( Air Compressor stalls when it ). Mike micmor68@gmail.com
Oct 25, 2009 | Air Tools & Compressors
1995 camaro fuel pressure
With the key ON engine OFF K.O.E.O. (cycle the key ON-OFF several times as pump only runs for 2 seconds) the pressure should be 41-47 PSI
May 12, 2009 | 1995 Chevrolet Camaro
Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Oct 11, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
89 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
