Question about Mitsubishi VS-45609 TV
TV Locked My Supra TV st29k22b is showing a key on screen and no button on the remote or the TV is working except the power buttons.
  • 3 more comments
  • tikboy_bibo Jul 22, 2008
  • alakdan Jul 22, 2008
  • mutwambakam Feb 20, 2009
    my problem is it shows a pudlock on the screen, only the button on of that is working no button on the rimote that is fonctioning
  • Anonymous Mar 12, 2009
    my tv show on key not working remot & tv only i channel work that show key
  • sreejithtec May 11, 2010
    My Supra TV st29k22b is showing a key on screen and ** button on the remote or front panel
  • 58 Answers
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Posted on Apr 02, 2008
Jvc tv lt-46n530 I cannot use the side button panel because when I press anything except 'Power' it brings up a big 'Key Lock' image on the TV screen.
You have to have remote to unlock the keylock. Without a remote you will not be able to access any other button than power button.
If you wish to get some more details check the bellow added link.
www.electro-medical.blogspot.com
Jun 29, 2016 | JVC Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Dish network code for a viore, volume/power not working
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 05, 2010 | Toymax Viore 42 in. Plasma TV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Can't get the remote to work at all
First press the SAT button at the top left hand side of the remote and release. Now try changing channels. If this did not work press the menu button twice on the receiver. It will usually be behind a pop open door on the right of the receiver. I f your receiver does not have these buttons you can access the system info screen by pressing the power button on the receiver while holding down the arrow left or right key.
Once you have come to the SYSTEM INFO SCREEN press and hold the SAT button on the top left side of the remote until all lights across the top light up. Then key in a two digit number e.g. 01-16 and press the #key. then press the record button and the remote address for the location you are trying to control should change to the number you keyed in. If this is the second location tv that was giving you issues exit out of all the screens on the receiver location tv and go to the other location and try the remote. If it is the tv where the receiver is located then you should now be able to use the remote to maneuver the yellow cursor across the screen. If you need further assistance please let me know. Thanks for using Fix Ya.
Mar 18, 2009 | DISH Network IR Remote Control
Use of univeral remote or code for Supra Tv and cannot veiw full picture.
Hi , my original remote control for Supra TV(ST29k22b) is broken .
I have a universal remote (Olympia - URC-22B25).
Can someone pls explain how to sync this new remote to my TV.
Also for some reason i cannot see the full pictire on the TV, all the edges of the pictures are like cut off or merged inside the TV.
May 24, 2008 | Televison & Video
Mitsubishi VS-45609 TV Logo
535 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
